Hi-res WL animation of AR 3315
- GreatAttractor
- Has thanked: 748 times
- Been thanked: 757 times
The seeing yesterday was not too great for 180 mm aperture, but I recorded >200 videos and got some good stacks, and even a usable animation. Taken with Intes M715 with Blackfly S (IMX 273) camera, Baader ND 3.8 solar film + Solar Continuum (10 nm) filter, stacked in AS!3 and processed with ImPPG.
I had L-R deconvolution disabled (it doesn't work that well on granulation), instead used 2 layers of unsharp mask (one for sharpening, another for slight denoising).
Animation: 80-second intervals (20 s when recording, but decimated 4:1 & blended together for the final animation), 1:12 h total:
I didn't use my SSM last year due to malfunction (which I didn't want to spend time on). It turned out to be just Arduino loose in its socket - I gave it a push and we're back up and running this season
Here are the readings for the above animation's duration (the thicker line is the running 30-second average):
and for the still image shown in the beginning:
One might ask: "how did you manage to get sub-arcsecond details if the seeing was mostly much worse?". But remember: an SSM gives a seeing value averaged over the whole solar disc and a certain time period (here: 1 s). There might still be moments when fragments of the FOV are undistorted for a small fraction of a second, and when taking 3k-frame videos at 3 ms exposure as I did here, this gives the stacker enough material to work with.
Bonus track: M1.0 flare in the same active region (90 mm refractor + Lunt 50 etalon, 30-second intervals, 40 min. total):
- Has thanked: 4413 times
- Been thanked: 4011 times
Re: Hi-res WL animation of AR 3315
This is an amazing session. Both animations are absolutely perfect.
Thanks for sharing it here.
- Has thanked: 3096 times
- Been thanked: 2198 times
Great stuff, love the animations.
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 6353 times
- Been thanked: 7408 times
- Has thanked: 17949 times
- Been thanked: 17093 times
WoW, and WOW, again! Very nice work Filip. The sun looks alive in that first animation. The spots show a lot of movement. The edges of the penumbra are mesmerizing! And the granules can even be seen to boil in the lower spot's light bridge!!
Nice M1.0 flare too. It's like an immense bolt of lightning which isn't far from the truth.
Two thumbs up!!
Two thumbs up!!
- robert
- Has thanked: 4 times
- Been thanked: 1282 times
Brilliant. Thanks
Robert
Robert
- Has thanked: 20940 times
- Been thanked: 10587 times
These are stunners Filip!
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
These are amazing animations Filip!.
- rigel123
- Has thanked: 8650 times
- Been thanked: 8884 times
Fantastic Filip, amazing to watch the movement in the penumbra.
- Has thanked: 612 times
- Been thanked: 404 times
- Has thanked: 65 times
- Been thanked: 4455 times
Superb images and animations Filip...well done
