Active Regions in Ha 30th May 2023
- Has thanked: 8544 times
- Been thanked: 8280 times
The morning started off beautifully blue, but by the time the Sun was within reach over the rooftops the clouds rolled in and I had to wait until late afternoon to set up and try my luck.
As is usual for me, the seeing conditions were dire and most SERs ended up in the bin. Two survived for further processing.
150 mm Double Stacked Refractor at f34 (with 2.5x PM)
Basler acA1920-155 um (IMX 174 sensor)
AS3! Stacking
ImPPG deconvolution and sharpening
PixInsight refining.
First up is AR13315
20230530_Ha_AR13315 by Stuart Green, on Flickr
...then AR13319
20230530_Ha_AR13319 by Stuart Green, on Flickr
These are softer than I would have liked, but you take what you can get (within reason).
The remaining ARs just didn't work out. Too blurry for me.
Thanks for looking.
Stu
AS3! Stacking
First up is AR13315
...then AR13319
Thanks for looking.
Stu
- Has thanked: 17845 times
- Been thanked: 16979 times
Re: Active Regions in Ha 30th May 2023
Stu,
They still turned out ok.
Thank you, James.
- Has thanked: 4379 times
- Been thanked: 3976 times
I also took photos in crappy conditions today, but you did better than me. Very nice details.
Petr
Petr
- Has thanked: 20783 times
- Been thanked: 10467 times
Great looking shots Stu! We;ve been sat under cloud coming in off the north sea for a few days now, a right old pain!
- Has thanked: 9307 times
- Been thanked: 6144 times
- Been thanked: 8905 times
Great Stuart I'm glad you are making good use of this sunshine even if the seeing is not quite so good.
Many thanks, everyone. Much appreciated.
- Has thanked: 6296 times
- Been thanked: 7311 times
Some fine results despite the challenging conditions!
Arne
Arne
