I saw amateur astronomers who tried to cool planetary cameras, I found on the net a "Mobile Phone Cooler, Convex Magnetic Heat Sink, Semiconductor Cooler, Noise Value Below 22 DB" seeing the attractive price I decided to take it and experimenting on my ASI174MM, I use the camera almost exclusively on solar photography and the cooling would have the purpose of keeping the temperature around 20° and perhaps reducing the noise a bit.
The first problem was how to fix the camera, I thought of a sort of light and easily removable cage, to help her husband and the 3D printer we easily made two rings with four holes, then using spacers with which we fixed the whole.
Turned on and connected, the system in about twenty minutes the temperature dropped by almost 10 degrees I would say acceptable, I also took two pictures and the noise is reduced. If you have any suggestions they are always welcome, I will try later to better test the system.
Taken again with a temperature of 31.7 °C
Taken again with a temperature of 24.0 °C
Thanks for your patience and sorry for my english
Ideas to cool the ASI174MM
- Ross
- Has thanked: 546 times
- Been thanked: 574 times
Daystar Quark cromosfera, 80ED Skywatcher, Player One Filtro ERF 1.25″ serie S per Quark Chromosphere, ASI174MM, Skywatcher AZEQ5, Baader Solar Continuum Filter, Baader Prisma di Herschel, Barlow 5x.
Re: Ideas to cool the ASI174MM
That's a great test, I've never thought about cooling the camera
- OlegLviv
- Has thanked: 918 times
- Been thanked: 943 times
vERY GOOD!!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Has thanked: 9723 times
- Been thanked: 5769 times
Hi Ross,
What was the exposure time for that test and where do you live?
Where can I find that phone cooler?
reagrds Rainer
reagrds Rainer
- Has thanked: 6296 times
- Been thanked: 7320 times
Very nice Ross.
I've been using this product to cool my ASI 174mm camera for a while now:
https://www.amazon.com/Cooler-Black-Sha ... TLDB7?th=1
I haven't done any testing of darkframes like you have, but I get similar drop in temperature (reported by FireCapture) when using the cooler. Not sure if it makes any significant noise reduction, but at least it keeps the camera in a better operating temperature (not overheating).
Arne
Arne
- Ross
My aim is exactly to keep the temperature bearablearnedanielsen wrote: ↑Wed May 31, 2023 4:50 pm Very nice Ross.
Arne
- Ross
the link is this
https://www.amazon.it/dp/B0B6PRHZ49?psc ... ct_details
I live in Italy in Maserà di Padova
- 1100.JPG (179.56 KiB) Viewed 357 times
Thanks.
Thanks.
- steveward53
- Has thanked: 1240 times
- Been thanked: 1501 times
Alternatively you can take the route I went down with the Altair Hypercam 174M Mono Fan Cooled camera with the fan built in ...
https://www.altairastro.com/altair-hype ... BxsSDt9I5s
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
- Has thanked: 20784 times
- Been thanked: 10477 times
Good results!
