Hello,
today i've decided to go a go at iNTI from Christian BUIL with SolEx.
So I tried iNTI with my spectro-coronagraph... Here are the first results that for once looks like the current sun
Also the nice prominence of the day with the spectro coro
600 lines/mm
1200 lines /mm
1800 lines/mm
and 2400 lines /mm : the doppler effect show the spicules and the velocity of the different parts of the prominences.
Here it can be clearly seen that a part of these prominences is arching over the chromosphere . The 2400 lines gives (in this case more information about the little prominence on the left )
Chris
1st SHG and proms of the day June 1st 2023
- Has thanked: 259 times
- Been thanked: 237 times
Last edited by ChrisHalpha2017 on Fri Jun 02, 2023 6:21 am, edited 1 time in total.
- Has thanked: 9710 times
- Been thanked: 5769 times
Re: 1st SHG and proms of the day June 1st 2023
Hi Chris,
Excellent. Do you have different disc sizes or do you move the disc in and out according to the Sun size.
Where is the disc exactly placed ?
Hi rsfoto
I have different sizes but as there is no motor its best not to use a disk that matches the sun perfectly : otherwize keeping the sun hidden becomes very hard as it will have to be more precise (wich is almost impossible by hand).
"Where is the disc excatly" : have a guess.... everything was explained in the link I posted about the making of a spectro-coronagraph. It's also the same of every spectroscope.
https://adsabs.harvard.edu/full/1985LAstr..99..295C
- Has thanked: 17970 times
- Been thanked: 8905 times
Great to see you tinkering to get a full disc
