1.6.23: AR3319 CaK field check
- Has thanked: 2977 times
- Been thanked: 2082 times
today i tried a new configuration for CaK imaging with only 2 lenses in the imaging train. Seeing was not the best but good enough to test it and check the field for aberrations due to the very long extension after the TV 2x barlow (in total ~16.5 cm).
So far the result seems to deliver (non cropped image).
TV 2x barlow, Antlia K-Line 3nm, lunt b1200 CaK filter, 9.5cm spacers, imx432
- 2023-06-01-0812_8.png (1.68 MiB) Viewed 520 times
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Been thanked: 4904 times
- Has thanked: 4210 times
- Been thanked: 3810 times
Re: 1.6.23: AR3319 CaK field check
Very beautiful CaK image.
Petr
Petr
Thanks Eric and Petr. Cant wait to try double stack mode once the second lunt filter arrives from Simon.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 6181 times
- Been thanked: 7142 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Worked well Dennis!
- OlegLviv
- Has thanked: 881 times
- Been thanked: 907 times
Nice! Antlia 3nm you put near sensor 432? Or front Lunt CAk 1200? Fist to sun Cak Lunt or Antlia 3nm?
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
The Antlia 3nm sits in front of the Lunt and serves as ERF in combination with the full aperture ERF.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- OlegLviv
Thank you! Do you have Cal Lunt 1.25? Or 2.0 with diagonal mirror? How do you stack Antlia 1.25 to Lunt Cal 1200?
Do you have big ERF CAK filter for full aperture?
How is your aperture?
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Yo Oleg, its the straight through Lunt b1200 CaK module (without front filters). The Antlia sits on a t2 nosepiece, this goes into the TV Barlow. Then this adapts to the Lunt in front (T2 thread).
Its a Baader Triband sct -> full aperture ERF on the Schmidt plate.
235mm.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 9144 times
- Been thanked: 6025 times
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Seems that the new set up worked extremely well Dennis - lovely image!
Clare & Peter
- OlegLviv
If I have 2.0 Lunt Cak cant stack Baader K -Line 5nm in front of the Lunt diagonal! Can stack Baader K -Line after Lunt Cak near sensor?Dennis wrote: ↑Fri Jun 02, 2023 9:55 am
235mm.
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
OlegLviv wrote: ↑Fri Jun 02, 2023 11:50 amIf I have 2.0 Lunt Cak cant stack Baader K -Line 5nm in front of the Lunt diagonal! Can stack Baader K -Line after Lunt Cak near sensor?Dennis wrote: ↑Fri Jun 02, 2023 9:55 am
235mm.
There is only 2" Versions, one is straight through, the other is with diagonal. I unscrewed the front part and that is a T2 thread.
The purpose is not stacking, but replacing the 2 Lunt ERFs in front with the antlia for ERF protection and offband blocking.
This configuration only works in combination with my full aperture ERF. Otherwise you damage the Antlia.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- OlegLviv
Ok if I use 80mm refractor cant damage Baader K-Line and Lunt?Dennis wrote: ↑Fri Jun 02, 2023 12:02 pmOlegLviv wrote: ↑Fri Jun 02, 2023 11:50 amIf I have 2.0 Lunt Cak cant stack Baader K -Line 5nm in front of the Lunt diagonal! Can stack Baader K -Line after Lunt Cak near sensor?Dennis wrote: ↑Fri Jun 02, 2023 9:55 am
235mm.
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
OlegLviv wrote: ↑Fri Jun 02, 2023 12:24 pmOk if I use 80mm refractor cant damage Baader K-Line and Lunt?Dennis wrote: ↑Fri Jun 02, 2023 12:02 pm
I dont know, you have to find out. But if it fails you might also damage the Lunt : /
So better try with only the K-line filter and check the temperature development.
To get more protection of the K-line you might want another filter in front like some sort of blue filter.
so in your case i would test with a array like this: barlow->hard coated blue filter ->baader k-line (->later lunt and camera).
no visual at all times.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
