Poor man double stack
- Has thanked: 4379 times
- Been thanked: 3976 times
I'm going to use the unplated Newton 250/F5.6 in H-a, so I'm testing how to get the narrowest possible band with minimum attenuation in H-a, because there will be very little light. I tried a combination of BF, TZ2x, BF, Quark on the AR150/F15 and the results look pretty encouraging. It's not a real DSII, but it's definitely a lot better than the single BF variant. I wonder if the N250 will shed enough light on that.
- sx1.jpg (405.33 KiB) Viewed 367 times
- sx2.jpg (412.69 KiB) Viewed 367 times
- sx3.jpg (429.79 KiB) Viewed 367 times
- sx4.jpg (477.61 KiB) Viewed 367 times
- KMH
- Has thanked: 658 times
- Been thanked: 772 times
Re: Poor man double stack
Very nice results, but I guess I don't understand what you're doing. How does using two blocking filters decrease the bandpass? Sorry if I'm missing something obvious.
Thanks!
Kevin
Thanks!
Kevin
Adding a second BF before the TZ2 increases image contrast similar to DSII. Not that much, the 3D effect is not as noticeable, but it's an improvement. By what mechanism does this improve contrast if not by narrowing the band? I'm not an expert on etalons and BF, maybe someone more experienced can explain it to us. I'm just sharing my knowledge from practice. I'll leave the theory to the experts.
- Has thanked: 3058 times
- Been thanked: 2161 times
Nice closeups!
about your mod: the results look good, but a comparison with the single bf would be king (or is it shown on the images? if so, what image is what?).
As far as i understand double stacking or using 2 bfs will not narrow the bandpass. What leads to improvements is usually the "cutting of the skirts" of the bandpass, so that parasitic light is reduced.
I still can see a double limb on the images, this would indicate that parasitic light hasnt been reduced much.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 6305 times
- Been thanked: 7324 times
One BF only.
- One BF only
- ss3.jpg (519.14 KiB) Viewed 316 times
- Been thanked: 10489 times
Promising results Petr.
To get the best out of both of those blocking filters they need to be tilt tuned.
That probably won't work. I have them stored without the possibility of tilting, but I might figure it out somehow. That's a good idea, thanks.marktownley wrote: ↑Fri Jun 02, 2023 7:31 am Promising results Petr.
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
