Yesterday seeing was very good. Locally, humidity was high and transparency not exceptional, as often happens in my land when the lower atmosphere is quite. I took the chance for imaging some active regions with my quark combo. Imaging train is the following. 130 mm refractor (+Daystar yellow ERF), UV/IR cut, barlow 5X tevelue (f 35) and asi 174. Attached some of the colorized close ups of the active region. I think I caught a small and quick flare from AR 3321, which, at first glance seemed the less active (is that a alpha class magnetic region ?). Around 9.15 UT I saw bright spots quickly gaining brilliance, and then fading away almost completely within 10 minutes.
All the best
Stefano
Active regions june 2nd H alpha
- Has thanked: 387 times
- Been thanked: 635 times
- 2023-06-02-0925_AR3321.jpg (597.85 KiB) Viewed 182 times
- 2023-06-02-0916_0-U-L-AR3321.jpg (484.28 KiB) Viewed 182 times
- 2023-06-02-0915_4-AR3321.jpg (544.83 KiB) Viewed 182 times
- AR3315color.jpg (247.13 KiB) Viewed 182 times
- 2023-06-02-0843_4-AR3319color.jpg (537.33 KiB) Viewed 182 times
- 2023-06-02-0905_7-U-L-AR3323 color.jpg (539.18 KiB) Viewed 182 times
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: Active regions june 2nd H alpha
These are lovely Stefano!
- Been thanked: 8907 times
