June 04 ,2023 ; prominence in UV with spectro coronagraph
ChrisHalpha2017
Has thanked: 259 times
Been thanked: 237 times
Post by ChrisHalpha2017 »
Hello ,
today a wonderfull day with no haze nor clouds.. and a beautifull prominence...
I tried the UV again and it was quite hard as I had to defocuse the refractor of about 12mm to get a sharp image of the prominence with 2 gratings : a 1200 lines @412nm and a 600 lines@ 500 nm...
But i'm pretty sure I would get better results once the collimator is refocused too in the UV.
H alpha with 600 lines /mm
tiff 600 2075 très nette BEST +++++++++_20230604_131341.304_UT.jpg (352.32 KiB) Viewed 891 times
tiff 600 tmm 2757 +++.jpg (702.29 KiB) Viewed 891 times
with 1200 lines/mm
1200 trmm.jpg (421.82 KiB) Viewed 891 times
with the 1800 lines :
1800 tmm.jpg (314.36 KiB) Viewed 891 times
and In the UV :
1200 lines @ 412nm
raie H K calcium.jpg (339.86 KiB) Viewed 891 times
and the 600 lines
600 trmm UV ++++.jpg (428.47 KiB) Viewed 891 times
Chris
rsfoto
Has thanked: 9733 times
Been thanked: 5777 times
Re: June 04 ,2023 ; prominence in UV with spectro coronagraph
Post by rsfoto »
Great
highfnum
Has thanked: 57 times
Been thanked: 1205 times
Post by highfnum »
great!
i knew you could do it
like that "other line on to will look for that next time I try
unfortunately clouds here today
ChrisHalpha2017
Thanks very much :) But I will rebuilt my collimator with a focuser because to get sharper images the collimator should be set according the wavelength. it doesnt make much difference in the visible range but when its UV light it makes a big difference. Especially when the focal lenght of the collimator gets bigger..
