Having read and followed the guide given by Douglas in regards imaging in the Helium D3 line https://groups.io/g/Solex-English/message/1032 I thought I'd have a go at it using my folded SHG yesterday morning. Used the thin line just above the Sodium D2 as mentioned in the guide as the starting point but I made things harder for me by choosing a larger ROI but after several attempts I eventually found the pixel shifted image which showed the faint Helium detail and created this gif using the D3 overlaid with the continuum image of the thin line I started with. Both images are single scans and I used IMPPG to align the images and Astrosurface to slightly process.
Alun
Attempt at Helium line 4th June 2023
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 18090 times
- Been thanked: 8934 times
- Alun_H
Re: Attempt at Helium line 4th June 2023
Thank you Alexandra.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 47 times
- Been thanked: 1535 times
That's a very good attempt. Did you try playing around with subtracting, dividing, etc of the two images? I didn't have much luck with that but I'm actually not very good with Photoshop.
If you overexpose the surface, you can sometimes see some Helium prominences. But the Hydrogen proms have to be really big in order to see much in Helium. Once you find the correct pixel location for the Helium line, you can do a variety of things like stacking images and fiddling with the exposure.
- Alun_H
Thank you Douglas,I did capture a prominence but the Protus image wasn't good enough to work with,next time I will try overexposing.
In regards subtracting I cannot fathom how to do it successfully in Photoshop (I only know the basic stuff) but I used the subtract tool in Astroart 8 and
here is the result
Alun
here is the result
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
Astroart seems to do a really good job with that. Looks like a good method. I played with the levels a bit:
But the GIF method of display seems more "real" to me.
