speed issue with ASI462 MM camera
- Been thanked: 2725 times
Hi all,
I have an issue with my all new ASI462 MM camera. This is the lasted model wth the DDR2 memory.
It is supposed to go up to 136 fps, but I can't go beyond 73 fps.
I tried with the last version of Firecapture and ASICAP. It makes no difference.
I have the latest versions of drivers. The PC is with on W10 64 pro.
No matter how much I try different USB traffic values and select (or not) High Speed in Firecapture, I don't exceed 73 fps.
It's the same with two different PCs, and regardless of the USB3 port used.
It's not a PC problem because I have quite a powefull configuration (I can run at 44 fps with the Apollo IMX 535 ).
On top of that, when I change the camera for the ASI290, and without modifying the configuration, I go up with 170 fps ...
Does anybody have a clue what can be going on ?
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: speed issue with ASI462 MM camera
Christian,
have you tried high-speed mode in ASICAP. Had a case last week with an old ASI120_S that did not want to go in high speed with FireCapture until I set in in High-Speed in Asicap. Now it works again in FC as well. (no clue why) Looking at the specs of the cam it will only run that speed in high-speed (10bit ADC)
Suppose you are not running 16bit?
Paul
Paul
- Rob63
- Has thanked: 599 times
- Been thanked: 620 times
I have the ASI462 MC and I can get a steady 128fps in firecapture 2.7 (usb traffic is set to 96) so the MM should have the same sort of performance.
If I switch off high speed mode it drops to 77fps so maybe it is a driver issue ?
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- KMH
- Has thanked: 658 times
- Been thanked: 772 times
You didn't mention it but I assume you must have experimented with bit depth? Both my 462MM and MC only get the high frame rate in 8-bit mode.
Kevin
Kevin
Yes, it was in 8-bit mode.
This could be a driver issue. The camera is "new" in the sense this is the new generation with the DDR3 memory.
I've got 64.8 fps with high speed mode = 0 (8 bits), and 73.5 fps with high speed mode = 1 (8 bits).
This is the same with Firecapture and ASI CAP
- Has thanked: 4379 times
- Been thanked: 3976 times
Sometimes changing the USB cable helps. I have a quality USB3 cable with which all cameras work at maximum FPS, except IMX533. With another cable it works at 44 FPS as it should. High-speed USB is sometimes alchemy. Storage speed also plays a role. If I want the maximum, I have to reformat the external SSD before using it. Simply deleting the files won't help. Only ... knows the reason.
- Has thanked: 3058 times
- Been thanked: 2161 times
I recently got the Player One version and had problems too. I fixed it by downloading the Camera SDK. From there i took the "PlayerOneCamera.dll" and copied it manually into the Firecapture installation folder. After that full speed.
I guess this is something because its new and all..
Did you try the firmware update?
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Thanks of your views guys.
- With the ASI290, I can run at 170 fps full-trame and 8 bits, which means 344 MB/s.
- With the Apollo-One Saturn-M IMX 533, I can run at 42 fps full frame and 8 bits, which means 370 MB/s !
On the opposite, with the ASI462 MM (with DDR3), I've only got 73.5 fps (8 bits, full frame, high speed mode), which means a mere 148 MB/s.
I have two SSD :
- one is 2 To in M2 format, writing at 3500 Mo/s,
- the other is 4 To in 2.5" format, writing at 530 Mo/s.
So, there is no deadlock on the computer side.
As suggested by Denis, and as the ASI462MM (with DDR3) is all new, there might be wrong somewhere.
I sent a message to ZWO ...
Indeed I've tried different USB3 cables, different USB3 port and two different computers.pupak wrote: ↑Mon Jun 05, 2023 7:18 pm Sometimes changing the USB cable helps. I have a quality USB3 cable with which all cameras work at maximum FPS, except IMX533. With another cable it works at 44 FPS as it should. High-speed USB is sometimes alchemy. Storage speed also plays a role. If I want the maximum, I have to reformat the external SSD before using it. Simply deleting the files won't help. Only ... knows the reason.
I have two SSD :
This should work for the zwo version:
https://www.zwoastro.com/downloads/developers
download the SDK
-From the lib folder in the unzipped SDK open the x64 folder
-from there take the "ASICamera2.dll" and place it into the firecapture folder (safe the old file in the firecapture folder)
-Copy the ASICamera2.lib file into the lib folder which is also in the FC program folder
download the SDK
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Thanks for the hint and detailed instructions Dennis !Dennis wrote: ↑Tue Jun 06, 2023 9:11 am This should work for the zwo version:
download the SDK
by christian viladrich » Mon Jun 05, 2023 7:49 pm
I've just tried, checked twice, but unfortunatly it makes no change :-(
For information, there was initialy no ASICamera2.lib file in the Firecapture folder. In any case, I copy the one from the SDK as you mentionned.
I hope to have a feedback from ZWO.
christian viladrich wrote: ↑Tue Jun 06, 2023 1:16 pmThanks for the hint and detailed instructions Dennis !Dennis wrote: ↑Tue Jun 06, 2023 9:11 am This should work for the zwo version:
download the SDK
Hm weird..
yes, otherwise you can also write Torsten Edelmann, maybe he already knows something.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Good idea. I'll probably wait one more day in case ZWO comes out with something. Then I'll get in touch with Torsten.
Just for the record, I know three other persons having this same "speed limit" issue with the ASI462 MM DDR3.
There is clearly a problem there.
Still waiting for a solution from ZWO.
- BGazing
- Has thanked: 289 times
- Been thanked: 353 times
Please post here if and when you figure it out...christian viladrich wrote: ↑Sat Jun 17, 2023 4:13 pm Just for the record, I know three other persons having this same "speed limit" issue with the ASI462 MM DDR3.
Lunt 80MT DS, 533/1600/462
About one week ago, a ticket was also put through a French importer.
No news since then ...
Some news, it seems there is a problem with the new firmware.
- Rob63
ZWO are usually pretty good at updating their software/drivers so hopefully there will be a fix soon.christian viladrich wrote: ↑Thu Jun 29, 2023 8:12 pm Some news, it seems there is a problem with the new firmware.
You do have to wonder about their testing though !
Problem solved ! With the new driver I 've got 136 fps :-)
ZWO will probably make it available soon on their website.
- Has thanked: 612 times
- Been thanked: 404 times
I should be happy then i didn't buy this camera yet, but i will not buy it anyway until i sell my other camera first to fund this, but good to know that there is an issue going around with this new model, so i think i will wait more and i am not in rush, hopefully ZWO can solve the issue, otherwise i will more to another brand of this camera model.
