second attempt caH and caK with open slit
- Has thanked: 57 times
- Been thanked: 1189 times
a bit cleaner than my first
used .ser files
interesting there is another line in there showing bright part of prom (its faint)
used .ser files
- Been thanked: 8791 times
Re: second attempt caH and caK with open slit
That's interesting, can you work out which line this is?
- Has thanked: 42 times
- Been thanked: 1487 times
I assume CaK is at the top? I don't see which other line you mean.
- Has thanked: 9412 times
- Been thanked: 5573 times
That could be Hydrogen 4101.7Å. Counting the dark lines from bottom to top it is the 3rd one.
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Nice work,so tempted to try fitting my surplus shed adjustable slit into the Sol'Ex so as to have a try at this method.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
thx rsfoto I believe you are correct
to smiths - H is on top see that line below - thats Aluminum I
Alun make sure you clean up edges of surplus shed before use
thats is what Im using
- Has thanked: 259 times
- Been thanked: 237 times
it's H gamma @ 410 nm ; dont forget that your spectroscope suffers from strong anamorphosis due to its configuration so the spectrum shrinks a bit...
Aluminium wouldnt show the prominences as clearly and brightly .
I noticed the same on my experiment :
Your results are getting better well done
What is the typical slit width you use? Is it different for different spectral lines?
my slit can open up to 3mm
about 1mm is average for Ha
HeD3 much less
so yes it depends on line thickness
Alun you will need to swap out grating - 2400 lpmm to high
im using 1200
Chris (who is IMHO expert on this) thinks 600 lpmm is better.
HeD3 much less
im using 1200
Hello to Alun : yes 600 lines/mm is the best (not in visual though ; only when using a camera) .
Look at the prominence I captured today June 7th with the 600 lines and you'll be surprised at the definition
But if you wonna make a SHG then 1800 or 2400 lines will be best.
You guys who do this should have a look at these slits: https://diy-optics.com/collections/used ... y-projects
He made some trial samples for me but could not get below 50 microns. They are laser cut, similar to ones from Thorlabs but much cheaper.
- Alun_H
Chris,at the moment the Surplus shed slit needs some serious cleaning up of its edges as John has mentioned but 600l/mm grating is on the shopping list
along with the multitude of other items i need ) I have a 2400l/mm in my folded SHG at the moment.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
