While it is fairly easy to spot the H-alpha line in the solar spectrum, the other Balmer series lines are harder to identify. To find H-beta, I typically have used an H-beta filter to help with the process. But this isn't possible with the H-gamma and H-delta lines. So I decided to use a combination of my Hydrogen spectral tube, foamboard SHG and direct sunlight to create some "maps". I found I could use these maps to find to correctly identify the lines (I had the spectral tube nearby so I could check if I was correct).
I took a series of screenshots of the solar spectrum as it appears using FireCapture with a ZWO 183MM camera. I used Photoshop to crop the images and adjust the levels a bit. If you click on the images, they appear with better resolution.
How to identify the H-beta, H-gamma and H-delta spectral lines
- Has thanked: 47 times
- Been thanked: 1522 times
- Arnold
- The Sun?
- Has thanked: 5 times
- Been thanked: 2 times
Re: How to identify the H-beta, H-gamma and H-delta spectral lines
I had also problems to identify lines and to focus the telescope in full sunlight using SharpCap. Sometimes it took only a lot of time, but in the worst case I got the wrong line. So I decided to write a python program to help with adjustment. At the moment, it is more or less a sketch of gui to see what is really needed. Getting the video from the ASI178 camera works, but motors and controller are still waiting on my desk. Target is support during adjustment and line identification, data rate is not sufficient for acquisition.
For line identification a tabular reference spectrum taken from BASS2000 is re-binned to the approximate spectral resolution and plotted as curve and as virtual spectrum next to spectrum and curve taken from SHG. Markers and annotations at lines from a table help to identify. The same gui tab holds also the buttons to control the grid adjustment motor. Focus of SHG was the least problem but I want to be quick when changing the range especially in UV. Therefore three regions along the spectrum are zoomed and also displayed as curves. Focus of telescope is supported by zooming on the edge of the spectrum as well as three zoom regions along the spectrum. Numerical measures of sharpness will be added later.
- Has thanked: 17970 times
- Been thanked: 8904 times
- Has thanked: 9710 times
- Been thanked: 5764 times
Hi Arnold,
Very interesting.
What about the focuser for the camera ?
Very interesting.
- Has thanked: 57 times
- Been thanked: 1202 times
- Arnold
- The Sun?
Hi Rainer,
I think my terminology was misleading. I called the focus of the camera "SHG focus", it focuses on thin spectral lines close to the observed line.
regards Arnold
regards Arnold
Hi Arnold,
So you focus telescope on slit and camera on the spectrum? What sort of logic will you use for doing that?
I have a motor on the telescope focuser tube and a motor on the camera.
- Arnold
- The Sun?
Hi Rainer,
I think the most critical area of the spectrum is violet and near ultraviolet, from 4000 to 3880A, containing Ca H, Ca K and CN band. Here the chromatic aberration changes very fast with wavelength, producing the "fishtail" in normal spectroscopy. Therefore we can not use any features too far from the target wavelength.
Most of sharpness measurement methods provided in libraries like openCV do not fit to our problem, as we have different sources of blurring in the two principal directions. I will use the terminus "vertical" for the cross slit or spectral direction and "horizontal" for the spatial direction along the slit, as we see the picture this way in SharpCap or Firecapture. If possible, I would like to use only simple means of evaluation, not looking at tilt or smiley of the spectrum.
We need to focus the spectrum first with the motor on the camera, using vertical details close to the line we want to observe. This focus is independent of the telescope focus, but due to flexture, temperature expansion and optical consideration it needs to be done shortly before acquisition. Maybe the region to analyze needs to be a little larger than the region we finally take in the video. So we have some 50 to 100 pixels on both sides of the target line to evaluate focus. Autocorrelation of signal or simple differentiation in vertical direction to get only the high frequency content may give good numbers.
For telescope focuser, things are more complicated:
First we have the width of the edges (e.g. from 20 to 50% of maximum signal) to determine sharpness. But in this case we need to exclude the spectral line itself, otherwise we will see a protuberance as lack of sharpness. This exclusion can be based on intensity or on area within our picture.
Second we have surface details along the line. Differentiation in horizontal direction will help, but we need to limit our analyze area to the line features. Turbulence and vibration will strongly change our measures, so I expect a lot of difficulties to arise here.
regards Arnold
regards Arnold
