Finally doing visual rather than fergling.
90mm F6.7 TS Triplet, 2" Baader UV-IR, 2" 40nm Optolong? T2 Diagonal, VK 3X TE, ES 2x TE, Quark Prom, Low profile focuser, 40mm Celestron
1.35 BST Light wind and high haze.
5.00 G8.30 Two broad base proms arching over. Bottom has bright extension reaching up. Top prom broad base leaning down.
8.00 G5.00 Two tiny sprays with low fuzzy proms above and below.
9.00 G3.30? Little X prom or waisted vase. Little bump above.
10.30 G2.30 Small pyramid prom with little low arm off angle above. Over it a curved up bow with the centre by the prom brighter.
11.30 G1.30 Fuzzy prom, standing Cormorant core. Tracery curving over from the top. Little corner fill in prom below.
2.00 Little bumps.
3.00 G9.00 Two stacked pointed arches. Fuzzy upright box below them both. Very faint seperated blob above.
Solar Links
https://www.swpc.noaa.gov/products/goes-x-ray-flux
https://solarmonitor.org/forecast.php?d ... 06®ion=
https://www.swpc.noaa.gov/products/solar-synoptic-map
Upcoming solar weather to left of -90
https://stereo.gsfc.nasa.gov/beacon/
https://www.raben.com/maps/
https://www.kso.ac.at/index_en.php
Cheers. Andrew
Observation proms 09/06/2023
- Has thanked: 3295 times
- Been thanked: 1887 times
- Been thanked: 4904 times
- Has thanked: 17583 times
- Been thanked: 16708 times
Re: Observation proms 09/06/2023
It's nice to see another do a detailed visual report. I feel not so alone!! :-) You always specialize in prominences and do so well in describing them.
Thanks Andrew!!
Thanks Andrew!!
The proms I see are generally a bit more fine detailed than Gong and even Stuart as today.
When I first used the Chromo it was at low FNo and not so good.
When I went to F40 it was much better.
I am now looking to see more disk details.
Been using a rotating polariser on the 40mm Celestron which helps.
Unfortunately its somewhere under the deck at this minute. I forgot the glass was held in by one of my Chinese filters repurposed as 20mm stops for PST and Quark mods.
I was using the 80mm F15 just. With 3x VK TE at F45. In the sweet spot I could see filaments above the big double prom and from the spot.
I could just see the big filament at the top.
I am stuck with MK1 eye image processing. I assume edge filaments have bee processed up.
Currently scanning Chromo settings for the F15.
Mak180 has a new SH focuser. So getting PST mod out again. Was having a play on the Visac 'F10' with the bits. Balance issue with bino-viewers but I noticed a longer dovetail bar on my hall little telescopes shelves. Also the Ioptron is complaining about Dec weight now with the Mak. One handset down but 2 Ioptrons so not an issue yet.
Cheers. Andrew.
Cheers. Andrew.
- Has thanked: 20448 times
- Been thanked: 10254 times
Glad you got some viewing in Andrew!
