sky condition not ideal but did it anyway
open slit
first attempt with 600lpmm open slit
- Has thanked: 57 times
- Been thanked: 1237 times
- Has thanked: 9911 times
- Been thanked: 5899 times
Re: first attempt with 600lpmm open slit
Nice results
Nice results
- Has thanked: 259 times
- Been thanked: 237 times
Very good
WHat are your impressions ? have you tried in the same time with the other grating in your spectroscope to see the diferences ?
I wonder if your collimator is really well set ? I mean with the slit PRECISELY at the focus of the collimating lens. I say that because I've added a focuser to my collimator and adjusted precisely the focus and the images are sharper.
There is an issue I nerver mentionned before but it has its importance :
You can have the sharp image of the spectral lines but the prominences image will remain blurry : that happens when your slit isnt exactly at the focus of the collimating lens ; even if you focused the imaging lens on the lines or on the order zero.
That means in other words that you can get a sharpt spectrum when the slit is very thin but once you open it the prominence image wont be sharp whatever you do ; unless you defocus the image of the sun on the slit.
(hope I wasnt too confusing).
- Has thanked: 18205 times
- Been thanked: 8956 times
