Conditions were very good early in the morning and also quite stable so I collected a lot of data. The following image corresponds to 90 GB of SER files (30 full disk scans). Technical details and other versions of the data are here: viewtopic.php?t=41173. Click on the first image to see at higher resolution. To see the second image at full resolution you need to open in a new tab.
Very good H-alpha SHG imaging conditions -- 10 June
- Has thanked: 42 times
- Been thanked: 1487 times
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Re: Very good H-alpha SHG imaging conditions -- 10 June
There were some technical problems when I tried to do Ca-H. Here is the top and bottom portions of the solar disk (there was a issue with the portion in the middle). The top one shows the fairly large prominence on the right side.
- Has thanked: 4206 times
- Been thanked: 3807 times
Superb photos.
Petr
Petr
- Been thanked: 16691 times
WoW, I am blown away! SHGs rule, that's for sure. The second, negative full disc is totally impressive!
Two thumbs up!!!
P.S. My images today show the proms and filaments. Yours make them a work of art!!
Two thumbs up!!!
- Has thanked: 20424 times
- Been thanked: 10243 times
Exceptional image Douglas!
