Select best frame for alignment points in Autostakkert?
DavidP
Has thanked: 169 times
Been thanked: 389 times
Post by DavidP »
I just realized that I can select a particular frame to place alignment points for stacking in Autostakkert.
Does anyone know if selecting a particularly good frame to align points on is beneficial?
Has thanked: 21946 times
Been thanked: 11182 times
Re: Select best frame for alignment points in Autostakkert?
I just let the whole thing run on auto.
nicosolcy
Has thanked: 1212 times
Been thanked: 909 times
Post by nicosolcy »
The alignment points are used across all frames, so it doesn't really matter which frame you choose to place them initially.
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
DavidP
Post by DavidP »
Sure, but does it not use your initial frame as a reference for identifying points another frames?
nicosolcy
Post by nicosolcy »
If you are going to place manual alignment points, you’d rather use a sharp frame to do best placement. But on auto, it doesn’t matter as the grid overlays the whole image.
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Wyvern
Has thanked: 101 times
Been thanked: 126 times
Post by Wyvern »
Yep, I'm with Mark on this!
Auto settings work pretty damn well for me. The more I fiddle with the settings, the more I seem to mess up the results!
Les
Seestar S50 Smart Telescope. 8" SkyWatcher reflector on HEQ6.
10" Meade S/C & 16" Meade reflector awaiting obsy "planning permission"!
Coronado PST & Lunt Herschel wedge for 120mm SkyWatcher refractor on EQ4.
Graves meteor detection system.
Canon 70d & ZWO ASI120mc for imaging.
Photoshop skills questionable.
