H-alpha and Ca-H full disk SHG images -- 7 July
- Has thanked: 62 times
- Been thanked: 1626 times
Lovely weather in London today. The morning offered good seeing and I was able to do tests with various setups: my 106mm APO triplet, 140mm Vixen NA, and Skywatcher 80mm f6.5. In this post, I show the results from the 106mm / 720mm refractor, which were the best. I only imaged to do the H-alpha and Ca-H lines. Open in a new tab to view at full resolution (there are a lot of details: the solar disk diameter is 2680 pixels).
- galaxie427
- Oh, I get it now!
- Has thanked: 218 times
- Been thanked: 17 times
Re: H-alpha and Ca-H full disk SHG images -- 7 July
I made a small modification to my dovetail SHG that helps to focus the two Pentax lenses that I use as the collimator and imaging lenses. I put foamboard disks over the helical focusers, which makes it much easier to make small adjustments. This is similar to a trick I saw some people use with SCT focusers.
- Been thanked: 2762 times
The comparison with the TS image taken by Pedro is quite interesting :
viewtopic.php?p=394290#p394290
We can see that the SHG has better spectral resolution than a triple-stack combination. The contrast of the fainter filaments is higher.
And the resolution of Doug's image is quite amazing !
- pedro
- Has thanked: 14 times
- Been thanked: 6834 times
Fantastic images there Doug, well done
Pedro Re'
- Has thanked: 18396 times
- Been thanked: 9045 times
- Alun_H
- Has thanked: 648 times
- Been thanked: 623 times
Superb images Douglas
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 17 times
- Been thanked: 80 times
Douglas,
Having some expereince with Sol'Ex, I know how dependent we are on excellent seeing but also cannot minimize the skill of the operator- these are exemplary!
Does daytime seeing follow a pattern in London or is it more random in nature?
I also am curious to know if you have to refocus the objective lens when going from Ha to CaH? and at what f/stop are your collimator and objective?
-Mike
-Mike
Yes, I found early in the morning is the best in London. Where I live it's kind of green and not so much concrete.
I have to refocus the camera going from 650nm to 400nm. The telescope also needs refocusing. The collimator seems to require less refocusing for some reason.
You should use the collimator and objective with as wide an f-stop as the lens allows. I'm using 150mm f/4 lenses.
I think Christian is referring to this particular image from Pedro. The title says "LUNT60, TS SM60/SM40". To my mind, the spectral resolution is fairly similar, but of course Pedro's triple stack has only (I believe) a 40mm aperture while I am using 106mm. So it's to be expected that the spatial resolution is better. I think it's very difficult to separate the effects of spectral and spatial resolution. I suspect an 80mm triple stack might be better than a 106mm SHG image -- but that kind of equipment would be difficult to assemble. The theoretical spectral resolution of my SHG is 0.1 angstrom at H-alpha, but it reality it's probably more like 0.2 angstrom. I suspect also that the spatial resolution isn't entirely limited by the telescope optics but is probably slightly degraded by the internal optics of the spectrometer. That's why I suggested that it might be more equivalent to something like a 80-90mm aperture triple stack.christian viladrich wrote: ↑Sat Jul 08, 2023 5:22 pm The comparison with the TS image taken by Pedro is quite interesting.
- Has thanked: 21381 times
- Been thanked: 10831 times
Phenomenal!
