Why is it that White Light solar filters should not be cleaned?
Solarscout
Has thanked: 9 times
Been thanked: 91 times
Post by Solarscout »
https://www.bhphotovideo.com/c/product/ ... l/overview
My EclipseView has this filter and a small piece of leaf fell on it. I removed it with fingers, then noticed fingerprints so I used a single use lens wipe to clean it. Then I noticed on the back there is a sign saying "Do not attempt to clean or disinfect filter material".
Do you never clean it in the case of dust or footprints? does trying to clean it make the material weaker?
steveward53
Has thanked: 1465 times
Been thanked: 1774 times
Re: Why is it that White Light solar filters should not be cleaned?
Post by steveward53 »
Because you will damage the coatings.
Baader Astrosolar film is coated on both sides making it less susceptable to 'pinhole' problems but the unidentified film in your filter may well be single side coated , as glass filters are , and therefore more likely to be rendered useless , nee dangerous , if the coating is damaged.
P.S. What are you doing to your kit that you need to clean footprints off your solar filter ... ? ... :lol:
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
Solarscout
Just flicking off some organic material from the cover and noticing a finger smudge. At least it's good now
