Why is it that H-alpha telescopes do not require special eyepieces?
Solarscout
Has thanked: 9 times
Been thanked: 91 times
Post by Solarscout »
Coronado has CEMAX eyepieces for use with its telescopes and Lunt also has its eyepiece line which is made of the same anti-reflecting coating material as their etalons. Do they have preferred eyepieces or it is not at all necessary?
Dennis
Has thanked: 3434 times
Been thanked: 2528 times
Re: Why is it that H-alpha telescopes do not require special eyepieces?
Post by Dennis »
Regular EPs transmit the visible spectrum of light without any problems. I dont see a gain in coating EPs specially for h-alpha wavelength, as long as you use quality eyepieces that have proper lens edge blackening etc. If you dont have that it could be a cheaper alternative to get these specialized eyepieces.
Triband C9.25
H-a: 2x Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Has thanked: 18637 times
Been thanked: 17784 times
Post by DeepSolar64 »
I have the full set of Coronado CeMax eyepieces and two of the Lunt eyepieces. All do well and does the Coronado CeMax barlow but I don't see much if any difference in performance at all vs " standard " non Ha optimised eyepieces. My TeleVue, Celestron and Edmund RKE eyepieces also do good as well. I also have a good Orion 16mm flat field eyepiece that does well too.
Any decent eyepiece with good coatings that's well corrected with blackened lens edges should do just fine.
Has thanked: 22020 times
Been thanked: 11210 times
It's marketing guff - so if people like all the same branding with their kit, they can do.
