Corona versus insect
george9
Has thanked: 159 times
Been thanked: 400 times
Post by george9 »
i went to Utsayantha Mountain on Oct 1 and was shooting the corona. In between my on-band shot and my off-band shot, an insect laid a gossamer thread across the dew shield in front of the objective. It was too thin to see normally, but it glinted for a moment when I was taking down the scope at the end of the session. The result was this glow from 5 to 11 o'clock with a sharp edge toward the bottom of the image.
Hripcsak 2023-10-01-1454_9-CapObj_____100r_48T_46reg rot contrast.jpg (56.86 KiB) Viewed 1447 times
As a result, I could not subtract these two images from each other:
Hripcsak 2023-10-01-1436_5-CapObj_____100r_48T_46reg rot.jpg (237.76 KiB) Viewed 1447 times
Hripcsak 2023-10-01-1454_9-CapObj_____100r_48T_46reg rot.jpg (237.45 KiB) Viewed 1447 times
So instead I did the best I could with a single on-band stack. While it doesn't reach the dim corona that it ought to, I think it has higher resolution. I suspect I need to work on my subtraction processing.
Hripcsak 2023-10-01-1436_5-CapObj_____100r_48T_46reg_adjust sharpen.jpg (189.5 KiB) Viewed 1447 times
And here is the satellite image:
SDO 20231001_142923_4096_0211 circle.jpg (247.93 KiB) Viewed 1447 times
George
Has thanked: 17256 times
Been thanked: 16319 times
Re: Corona versus insect
Post by DeepSolar64 »
George,
I didn’t know you were using a tunable filter. It must be of a very narrow bandpass. I know professionals use green wavelength filters for coronagraphy. What wavelength is it? 530nm?
These look really nice. You are one of a very few that can view the corona without a solar eclipse!
James.
Has thanked: 19936 times
Been thanked: 9926 times
Brilliant thanks George, amazing the scattering effect of that thread.
Has thanked: 17265 times
Been thanked: 8671 times
Every time I see these images I find them incredible :bow :bow :bow
Alexandra,
So do I. George and Klaus should be an inspiration to all of us to do coronagraphy if possible. It's a facet of amateur solar astronomy that few even attempt, much less succeed at. I am talking about true corona here. Not coronagraph style prominence viewers. Unfortunately many of us do not have dry deep blue skies which this requires.
And if they were only a commercially made true coronagraph available. Or an available kit like the Sol-Ex.
arnedanielsen
Has thanked: 6004 times
Been thanked: 6881 times
Post by arnedanielsen »
Very impressive results George!
Arne
george9
Post by george9 »
Thanks, all.
James, yes, that is 5303A for Fe XIV. The FWHM is about 1.2A by using two 2A filters. It is slightly tunable in the sense that if I drop the temperature by over 12C, it goes off band. 20C is pretty much completely off band. At 12C it is far enough to use as a negative image.
On the skies, yes you need to occasionally have blue skies, either in your backyard or by driving somewhere. Keep in mind, though, that I have gotten the corona from the Peconic Bay on Long Island, NY. It's not known for deep blue skies, and it is at sea level. Connecticut can be humid and hazy, and I got pretty good images this summer.
George
