Today's SUN (202310129 | Sol'Ex First ligth
- pedro
- Has thanked: 14 times
- Been thanked: 6766 times
WEB LINK:
https://pedroreastrophotography.com/sun ... 23-10.html
Solar imaging session (20231012) | Pedro RE'
Sol’Ex Spectroheliograph first light (FS60C F/5.9)
TV NP127 F/5.2 | FS60C F/5.9 Sol’Ex first light
Sol’Ex Spectroheliograph | Firecapture & INTI
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (202301012) H-alpha (09:30 UTC). TAKAHASHI FS60C F/5.9, Sol'Ex, ZWO ASI174MM
SUN (202301012) H-alpha (08:30 UTC). TV NP127 F/5.2, DS SM90II/SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (202301012) H-alpha (08:30 UTC). TV NP127 F/5.2, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20231012) CaK, G-Band, WL & H-alpha (08:30 UTC). TV NP127 F/5.2, PGR GRASSHOPPER 3 GS3-U3-28S5M
WEB LINK:
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
Pedro Re'
- Has thanked: 17994 times
- Been thanked: 17141 times
Re: Today's SUN (202310129 | Sol'Ex First ligth
Pedro,
Impressive work with the Sol-Ex!! You did very well for a first timer. You will be on this like a flea on a cat very soon doing professional-grade images like you do with all of your other stuff.
- pedro
Thanks James
I also think it is a good first image (first light). I will have to use a camera with smaller pixels (I used the AS174MM that is not great for this kind of images). It is not easy to tune everything and also focus and align the Sol'Ex to get the most of it. I will try harder next time.
Pedro Re'
Pedro,
They do appear to be more difficult to use than conventional etalon filters. I would almost certainly have to purchase a good tracking equatorial mount for the use with a Sol-Ex equipped scope. Most of my mounts are non motorized altazimuth, except for the AZGTI which is a motorized alt-az. I struggle with these mounts often when imaging. I do plan to get a tracking equatorial with a Hinode solar guider in the future.
Good luck with your use of the Sol-Ex. I look forward to seeing your results.
- pedro
There is a recent Youtube video (in french) concerning the use of the Sol'Ex without any mount. Check it out (you can turn translation on I guess)
Pedro Re'
- KMH
- Has thanked: 665 times
- Been thanked: 788 times
Great first light! If I may make a suggestion, could you maybe do a side-by-side comparison of the two Ha results, both mono and same orientation?
I look forward to seeing more.
Kevin
Kevin
- pedro
Thanks Kevin
Here is the comparison
SUN_TV_NP127_20231012_GS3-U3-28S5M_SolEx_comparison by Pedro Re', on Flickr
Pedro Re'
- Has thanked: 20997 times
- Been thanked: 10624 times
these are all excellent Pedro!
- DanielBrousseau
- Been thanked: 139 times
Impressive Pedro,
Merci beaucoup,
Merci beaucoup,
Phantom 140 f/6.5, SW newton 254mm f/5, Quark Chromosphere, Lunt 60mm Universal, Baader ceramic wedge, ASI174 mono, ASI294 mono, ASI290 mono,
Sherbrooke, Québec, Canada
- Has thanked: 18146 times
- Been thanked: 8946 times
These are absolutely splendid comparisons Pedro
- pedro
Thanks a lot guys, greatly appreciated
Pedro Re'
- Has thanked: 6389 times
- Been thanked: 7443 times
- pedro
Thanks Arne
Pedro Re'
