Moon approaching Sun over corona before first contact
george9
Has thanked: 159 times
Been thanked: 400 times
Post by george9 »
I went out to Utah to get the Moon in front of the corona, and here is an early shot. I have a lot of processing to do and to create a montage of the Moon approaching the Sun. But here is one shot with minimal processing with the Moon’s shadow coming in from the right before first contact. Just happened to be over a nice active region. Remember, the dark black thing in the middle is my cone. The Moon is the curved shadow to the right of that.
This is taken from Comb Ridge in SE Utah at 9:07 local time in my 50mm coronagraph (viewtopic.php?t=42685).
I have never been at the centerline of an annular before, and I found it a lot more moving than expected, best in the eclipse glasses. Just something about that perfect ring.
George
Hripcsak Moon approaching Sun 2023-10-14-1507_1.jpg (178.25 KiB) Viewed 2655 times
george9
Re: Moon approaching Sun over corona before first contact
Post by george9 »
You may have to shift the image to the left to see the Moon on the right. Not sure why it didn't resize it. George
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Fantastic image, George!
Did you this photo intentionally to show the moon on the corona background?
Very unique photo! A 100% SPOD !
Dennis
Has thanked: 2854 times
Been thanked: 1995 times
Post by Dennis »
Congrats on catching this, very impressive.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Has thanked: 8272 times
Been thanked: 8017 times
Post by Carbon60 »
Amazing work, George. Congratulations on such a unique result.
Has thanked: 17265 times
Been thanked: 8671 times
That certainly is a very unique picture as I expect no one else was looking at the corona. Scientifically, this proves you are looking at the corona with your set up, as it would be impossible to see the Moon at this stage otherwise :bow :bow :bow
pedro
Has thanked: 14 times
Been thanked: 6508 times
Post by pedro »
This is brilliant George, a fantastic image
Has thanked: 17256 times
Been thanked: 16319 times
Post by DeepSolar64 »
Montana wrote: Mon Oct 16, 2023 9:12 am That certainly is a very unique picture as I expect no one else was looking at the corona. Scientifically, this proves you are looking at the corona with your set up, as it would be impossible to see the Moon at this stage otherwise :bow :bow :bow
Ditto!! Awesome. Excellent shot! :bow
arnedanielsen
Has thanked: 6004 times
Been thanked: 6881 times
Post by arnedanielsen »
This is a fabulous image George! Thanks for sharing!
Arne
george9
Post by george9 »
Thanks, all. Yes, I was hoping to get this shot. I have a series of images and hope to show the early progression. There was a haze, and I could not get negative shots to subtract, so it is limited how faint I can go on the corona.
George
George. You are the only one here that could image the moon before first contact. That is so awesome. I wonder if it could have been seen visually?
James.
EricF
Has thanked: 1222 times
Been thanked: 268 times
Post by EricF »
I'm still staring at that image!
Imaging the Moon before first contact. That may be a first.
Just excellent!
george9
Post by george9 »
It would have been visible to the eye before first contact, but only as it got closer. That active region was visible before I attached the camera, so I would have seen it. The problem was that I had to choose between imaging and visual. It only takes a minute or two to switch, but that's long enough to disrupt the sequence of the Moon approaching. I should follow Klaus's example to allow switching with just a lever. The challenge is that my backfocus is limited, and now that I added a reducer in front of the camera, my backfocus is more limited. A bigger camera would help. I should use a Baader T2 Heavy Duty Quick Changer, although I am not sure I even have 15mm free.
George
nicspenceryork
Has thanked: 5665 times
Been thanked: 1199 times
Post by nicspenceryork »
Really interesting to see your unique image, thank you.
astroshot
Has thanked: 304 times
Been thanked: 201 times
Post by astroshot »
Very nice George! Well done!
Very interesting method used.
Michael.
Michael in Kildare, Ireland.
TEC140
Coronado Solarmax 90
Daystar 0.6A T-Scanner
george9
Post by george9 »
Another shot at processing, from 15 minutes before first contact to one minute after. I used curves to try to highlight the Moon coming in better. You should be able to see the Moon in all seven images. You will probably need to click on the thumbnail to see it better.
George
Hripcsak 2023-10-14 eclipse corona montage 5.jpg (317.23 KiB) Viewed 1076 times
Absolutely incredible :bow :bow :bow
KMH
Has thanked: 604 times
Been thanked: 678 times
Post by KMH »
Stunning!!! The work you and Klaus have done with corona imaging is quite amazing.
Kevin
