Montage of Moon approaching Sun in front of corona
george9
Has thanked: 189 times
Been thanked: 444 times
Post by george9 »
This is taken from Comb Ridge in SE Utah in my 50mm homemade coronagraph at 5303 Angstroms during the annular eclipse. Universal times label the images, and they all have south up. The dark black disk in the center is the shadow of the coronagraph’s obscuring cone. The Moon is a more subtle grey disk due to scattered light in the atmosphere. At 14:59UT, the Moon is seen just coming in from the left (west). At 15:08, it is more prominent just before first contact. At 15:57, it is between first and second contact. At 16:15, the far edge of the Moon can be seen against the corona. At 16:26, minutes before second contact, the west corona can been seen well peaking from behind the Moon, and the coronal streamers can be seen all around.
George
Hripcsak 2023-10-14 eclipse corona montage 3.jpg (374.91 KiB) Viewed 5891 times
george9
Re: Montage of Moon approaching Sun in front of corona
Post by george9 »
Maybe this one is more clear.
George
Hripcsak 2023-10-14 eclipse corona montage 3.jpg (452.7 KiB) Viewed 5890 times
rigel123
Has thanked: 9425 times
Been thanked: 9626 times
Post by rigel123 »
Really cool George!
Has thanked: 18937 times
Been thanked: 9272 times
Amazing George :bow :bow :bow
SJohnson
Has thanked: 374 times
Been thanked: 252 times
Post by SJohnson »
Awesome shots George and congrats on the SPOD!
george9
Post by george9 »
Thanks, and thank you for the SPOD.
FYI, here is a closeup of the 15:08.
George
Hripcsak 2023-10-14-1508_0-CapObj_____100r_48T_30reg half.jpg (253.42 KiB) Viewed 5742 times
Has thanked: 18669 times
Been thanked: 17811 times
Post by DeepSolar64 »
Absolutely amazing work George. Very SPOD worthy! Congratulations 🥳.
James. 😊 👍🏻👍🏻
pedro
Has thanked: 15 times
Been thanked: 7100 times
Post by pedro »
Amazing images, congrats on APOD George
Has thanked: 8897 times
Been thanked: 8682 times
Post by Carbon60 »
Superb images. Very nicely done, George.
Congratulations on SPoD.
KMH
Has thanked: 714 times
Been thanked: 918 times
Post by KMH »
That's a really amazing collection - quite an achievement!
Kevin
Has thanked: 22096 times
Been thanked: 11249 times
Incredible! Post a picture of the setup if you can George!
george9
Post by george9 »
Here the coronagraph is set up at Comb Ridge in southeast Utah, USA. Other than the battery, that all came with me from New York.
George
That looks like a Losmandy AZ8 mount like I use but with a different mount head. The setup is quite large for a 50mm aperture.
oriolestation
Has thanked: 522 times
Been thanked: 648 times
Post by oriolestation »
Exceptional results, George. Especially working in the field as you were. Bravo!!
Cheers!
Jim Ferreira
Oriole Station
https://www.astrobin.com/users/oldfrankland/
george9
Post by george9 »
Thanks again.
The mount is a new ZWO AM5 harmonic drive unit that I like a lot, on a TC40 pier with PE160 pier extension.
The 50mm is f/20 for 1000mm, the white dew shield helps avoid dust (maybe 300mm), and then the chronograph is a series of lenses that adds another 400mm. So about 1700mm total. The tube is about 90mm, which helps disperse the light, but I am not really exploiting it well because I have only 43mm around the cone.
George
I thought that might have been an AM5 mounted on the Losmandy tripod.
Has thanked: 157 times
Been thanked: 898 times
Post by Valery »
DeepSolar64 wrote: Fri Oct 20, 2023 2:04 am I thought that might have been an AM5 mounted on the Losmandy tripod.
Ditto!
Valery.
Post by Valery »
George, for me your series of images is a SPOY! Yes, SPOY!
thesmiths
Has thanked: 79 times
Been thanked: 1644 times
Post by thesmiths »
Yes, probably solar images of the year.
Amateurs that can view/image the solar corona are very rare. Cutting edge!!
george9
Post by george9 »
I processed my last image before second contact. I was busy looking at the Sun during annularity, and then some light cirrus moved in. Not enough to notice in white light but bad for coronal viewing.
With the Sun 90% covered, most of the scattered light should be gone, so this should be a great image. (In fact, I have seen some simple white light camera images by others that show the innermost corona where the Moon just touched the edge of the Sun.) I think it may be better than my previous images but not by that much.
I could not do a negative image for this one because it takes 10 minutes for the oven to cool. I had to subtract a linear gradient for some reason. I could probably do better. The finger-shaped dark region at 7 o'clock is a dust artifact on the camera window that I missed. This version is flipped so north is up.
The SDO satellite image is shown below it. Good match.
The fact that my other images almost match this shows that the subtraction of a negative really helps.
George
Hripcsak 2023-10-14-1626_8-CapObj_____100r_48T_30reg corona sharp up.jpg (378.84 KiB) Viewed 5313 times
SDO 20231014_162935_4096_0211 ring.jpg (304.41 KiB) Viewed 5313 times
This still looks really good, George.
astroshot
Has thanked: 357 times
Been thanked: 279 times
Post by astroshot »
That's amazing work George!
Really impressive!
Michael.
Michael in Kildare, Ireland.
TEC140
Coronado Solarmax 90
Daystar 0.6A T-Scanner
This is still absolutely beautiful and superb :bow :bow :bow
Montana wrote: Mon Oct 23, 2023 9:17 am This is still absolutely beautiful and superb :bow :bow :bow
Agreed. And ground breaking in amateur solar astronomy.
