8th Feb. SE Australia..
There is a nice large sunspot group AR3576 that is currently travelling across the Sun's disc (E to W). I measured it this morning at approx. 145,000 km across x 72,400 wide. The first and second images shows it and the other sunspots at 540 nm. The third image shows the eastern sector of the Sun and AR3576 at H alpha (656 nm) wavelength. All images are single exposures with a Canon 550d. Thanks for viewing.
8th Feb Large sunspot
- Been thanked: 1760 times
- Has thanked: 19414 times
- Been thanked: 18525 times
Re: 8th Feb Large sunspot
AR13576 does not look to have changed much since I imaged it in K-Line this morning.
Nice work!
Nice work!
- Has thanked: 2859 times
- Been thanked: 5433 times
- solar
- Has thanked: 409 times
- Been thanked: 2175 times
Nice work John. They are really good white light images and clearly shows just how big it really is. As James said it does not look to have changed a lot in the HA image.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 14, C8 CG5, Megrez80, Lunt 100 DS. EQ 8
ASI 120mm 290mm 432mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
Please note, the sunspot images were taken at 540 nm not WL (which uses the whole visible spectrum).
Thanks.
Thanks.
- Has thanked: 20596 times
- Been thanked: 9922 times
- Has thanked: 10673 times
- Been thanked: 7125 times
Great shots of AR3576, John. Nice to have some measurements to compare !
- Has thanked: 7765 times
- Been thanked: 9230 times
- Has thanked: 23766 times
- Been thanked: 12125 times
Nice images thanks John!
