Can't install Solar tools in Pixinsight
- AndreaGirones
- Has thanked: 91 times
- Been thanked: 190 times
Hello All
I am trying to install the Bill Blanshan's Solar Tools process into Pixinsight. I added it to the repository in the normal way but still cannot find it. I have also tried the supposed fix, "reset updates" twice to no avail.
Any other thoughts?
Andrea
Any other thoughts?
Andrea
Andrea
Lunt 40mm
Starfield Optics 102 scope
Daystar Quark Chromosphere
Daystar 0.5x reducer
Televue 2.5x Powermate
Lunt 1200 Calcium K blocking filter
Apollo Max ASI174MM ASI290MM
Instagram https://www.instagram.com/andrea_girones/
Flickr: https://flic.kr/ps/429jub
Astrobin : [url]https://www.astrobin.com/users/Agirones/[url]
Lunt 40mm
- Has thanked: 9503 times
- Been thanked: 9232 times
Re: Can't install Solar tools in Pixinsight
Hi Andrea,
I've just done it now, so I know it works....
I updated PI to the latest version (mine was old!), which may or may not be necessary.
Anyhow, this video is really helpful:
https://www.youtube.com/watch?v=3yzfH5x5Smg
I noted the importance of 'Resetting Updates' mentioned at around 8:30 into the video. I had to perform this step in order for the toolbox to show up under the process tab. Not sure why this isn't working in your case.
Good luck.
Good luck.
- rigel123
- Has thanked: 10676 times
- Been thanked: 10655 times
It wasn’t until I updated PI that I was able to load it and I thought I had the most recent update already!
Andrea, did our answers help you?
- Vigo79
- The Sun?
- Has thanked: 4 times
- Been thanked: 9 times
Hello
I have the same problem. I added the repo link and nothing happens. Then I reseted the plugins and all my plugins was updated new. But I can not see the solar toolbox. Pixinsight version is 1.8.9-2 build 1598.
Is there an other solution to solve this problem?
____________
https://www.astro-winkerling.de
- rigel123
Hmm, I currently have 1.8.9-2 1597 and it loaded OK. Have you restarted Pixinsight and in the Process choices it just says Solar.Vigo79 wrote: ↑Thu Apr 11, 2024 11:21 am Hello
You can check your Manage Your Repositories and make sure you had the correct address. I messed that up a couple of times.
- solarchat
- Site Admin
- Has thanked: 87 times
- Been thanked: 1574 times
I have owned pix insight since it first came out and have struggled with it many times usually giving up in the end. I see all of those guys teaching classes at NEAF every year And have developed a strong dislike of having to use the program. lol
Is there a fee for the Solar toolbox and has anyone actually used it? I would hate to think that I will have to get out this program again to work on my solar images.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
- Vigo79
- The Sun?
Yes! I tried the repo link with and without the last / too, tried many different things. I copied the link from youtube. Maybe I will deinstall and install PI newVigo79 wrote: ↑Thu Apr 11, 2024 11:21 am
What happens when you copy the link into your browser? I got a 404 error.
____________
- rigel123
It works fairly well and it's free, you just really need to be gentle with the sliders. It works really great to pull proms out without affecting the disk once you have a chance to play with it. I've had a Love/Hate relationship with this program (Pixinsight) since it came out and am always amazed at the results from those that really know how to use it. But not being a formula person, I have struggled just like you. At least now for DSO's they have the Script, Weighted Batch Preprocessing which takes a lot of the work out of what it used to be! Using PixelMath, forgeddaboutit!solarchat wrote: ↑Thu Apr 11, 2024 12:57 pm I have owned pix insight since it first came out and have struggled with it many times usually giving up in the end. I see all of those guys teaching classes at NEAF every year And have developed a strong dislike of having to use the program. lol
- rigel123
I ended up adding it manually by just typing it inVigo79 wrote: ↑Thu Apr 11, 2024 1:06 pmYes! I tried the repo link with and without the last / too, tried many different things. I copied the link from youtube. Maybe I will deinstall and install PI newVigo79 wrote: ↑Thu Apr 11, 2024 11:21 am
- Vigo79
- The Sun?
Halleluja.... I got it. Downloaded the newest version of PI build 1605 and there was no problem to install it. Thanks for your help!
____________
- Petrus
- Has thanked: 1755 times
- Been thanked: 875 times
Yes, there is a free program called SolarFinish. It used to be and still can be used with only a command prompt, but has now also more usable window with sliders. Suitable for full disk images only. I liked this one more than Solar Toolbox for PI, which can be used for close up views and full view too.solarchat wrote: ↑Thu Apr 11, 2024 12:57 pm I have owned pix insight since it first came out and have struggled with it many times usually giving up in the end. I see all of those guys teaching classes at NEAF every year And have developed a strong dislike of having to use the program. lol
https://github.com/GregAlt/SolarFinish
~ Petrus ~
Flickr
Flickr
- rigel123
Glad you got it!
- AndreaGirones
Hello All Sorry for my late reply ( i am not so good at using this format. The trick was installing the most recent version. I had avoidede it because of a probelm with Windows but as soon as I updated it worked thanks you all for your help!.
Andrea
Lunt 40mm
Lunt 40mm
