IMPPG quits unexpectedly
acroflyer
Been thanked: 2 times
Post by acroflyer »
IMPPG disappears with no message. Two places where this has happened are 1) when dragging points on the tone curve. The dot turns red and when released the screens turn blank, and 2) in image alignment on the solar limb. Same behavior, just disappears with no message. I have downloaded the most current release with the same result. I have tried it with and without graphic acceleration, same result.
Has anyone else had these problems and is there a fix?
Mike Mulcahy
rigel123
Has thanked: 9355 times
Been thanked: 9571 times
Re: IMPPG quits unexpectedly
Post by rigel123 »
acroflyer wrote: Tue Apr 23, 2024 7:37 pm IMPPG disappears with no message. Two places where this has happened are 1) when dragging points on the tone curve. The dot turns red and when released the screens turn blank, and 2) in image alignment on the solar limb. Same behavior, just disappears with no message. I have downloaded the most current release with the same result. I have tried it with and without graphic acceleration, same result.
Mike Mulcahy
Send a note to Filip (GreatAttractor) and he should be able to help you out
memberlist.php?mode=viewprofile&u=568
Peterm
Has thanked: 2006 times
Been thanked: 1773 times
Post by Peterm »
Mike Mulcahy
Hi Mike,
Yes, with the current version 1.9.1 beta I had the same issues. I feel bad that I forgot to report it because I went back to 0.6.5 (this is stable no issues for me) and I completely forgot about it, as well as lack of Solar time due to weather. Your post is accurate with my experience.
Peter
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
Martin_S
Has thanked: 1090 times
Been thanked: 3253 times
Post by Martin_S »
Hi Mike , have you tried using Wavesharp? It's very stable and does everything except image alignment.
Alto
Has thanked: 1083 times
Been thanked: 444 times
Post by Alto »
I had problems this morning getting it to accept a 4-pane Mosaic of something like 35k size. Just refused to open. Gave up and haven't reported it as I'm not too sure it wasn't me or an older spec laptop.
Call me Geoff.
