Coronado BF30 rusted and repair
rsfoto
Has thanked: 10719 times
Been thanked: 6220 times
Post by rsfoto »
¡WARNING! ¡NOT FOR VISUAL USE!
The BF30 which I am using since long time got rusty many years ago and Iread here that instead of an ITF a H-alpha filter could be used. I had a 2" spare one, took it our of the mounting and glued it wih silicone at the front.
Now I found out the unmounted 2" filter fits into the 2" filter housing so I decided to print two washers and sandwich the H-Alpha filter inbetween. One washer has a bit of flocked paper so the H-alpha filter does not crack when tightening the ring.
As I have two more I offered a friend if he wanted to try one and saw it was rusted too so I decided to use a 1.25 H-alpha filter instead of the rusted ITF and below the solution. I printed an adapter in the outer size of the ITF and inside a M28.5x0.6 thread.
Has thanked: 22413 times
Been thanked: 11473 times
Re: Coronado BF30 rusted and repair
Nice mod thanks Rainer
Bob Yoesle
Has thanked: 600 times
Been thanked: 898 times
Post by Bob Yoesle »
Hi Rainer,
Just an important safety note for visual use that most of the newer H alpha filters by themselves are probably NOT a replacement for the ITF. The ITF is blocked from the deep UV to ~ 5000 nm to OD5.
Most dielectric filter coatings are only blocked out to ~1200 nm. It most certainly is not blocked out to > 3000 nm of the solar irradiance profile. For this you'd have to add a KG3 filter.
It would need to have OD5 blocking in the 300-790 nm range. Unless it is on a RG610 or RG630 substrate (like the ITF and older nighttime H alpha filters), it likely it is no more than OD4 in this range.
Bob
rsfoto
Post by rsfoto »
Bob Yoesle wrote: Thu Apr 25, 2024 12:25 pm Hi Rainer,
Bob
Thanks Bob and yes I know that but I do NOT do any visual observing. Only imaging.
I just mofified my original posting and added a WARNING notice to it
