Total Eclipse Temperature Graph
AstroBees
Has thanked: 245 times
Been thanked: 294 times
Post by AstroBees »
The telescope mount was in the shade until around 11am local time so that is why the graph is rather smooth from 9am till around 11am. Then it becomes a bit more variable but the eclipse is still very obvious. We had clear skies the entire time.
Lunt 80mm Ha double stack
Explore Scientific ED152 CF APO with Baader ASTF Whitelight film & Baader Solar Continuum filter
All piggybacked on a Astro-Physics Mach 1.
KMH
Has thanked: 710 times
Been thanked: 902 times
Re: Total Eclipse Temperature Graph
Post by KMH »
That's a pretty dramatic drop!
Kevin
rsfoto
Has thanked: 10475 times
Been thanked: 6128 times
Post by rsfoto »
Hi Greg,
Tha is interesting. At my place it just dropped about 2.5°C to 3°C
Has thanked: 18816 times
Been thanked: 9209 times
That's an 8 degree drop in temperature for a full eclipse compared to the partial of Rainer's 2-3 degrees, very interesting :hamster: :hamster: :hamster:
AstroBees
Post by AstroBees »
Alexandra, it's more like 14.8° drop from C1 to the low point which trails a bit behind C3, the end of totality.
Apologies Astrobees, I converted to Celsius to be comparable with Rainer's partial eclipse temperatures
30.5 degrees to 22.2 degrees
allhoest
Has thanked: 880 times
Been thanked: 554 times
Post by allhoest »
I have similar observations (From arkansas).
Here are 2 ambient temperature readings taken during the eclipse.
The sensors are placed in the shade in trees.
Here is for the first sensor (671), red curve.
The highest value recorded before the eclipse is 28.2°C (791 04-08-2024 13:40:08 28.2)
The coldest value during the eclipse is 21.2°C ( 1341 04-08-2024 15:11:48 21.2)
Or a decrease of 7.0°C
Here is for the second sensor (512), red curve.
The highest value recorded before the eclipse is 28.0°C ( 880 04-08-2024 13:54:25 28.0)
The coldest value during the eclipse is 20.5°C ( 1356 04-08-2024 15:13:45 20.5)
Or a decrease of 7.5°C
In both cases the value rises to 29°C or more after totality, but I stopped the recordings too early.
Alex
2024-Apr-08
