Monster Prom & Activity on the Western Limb | HA High Res | May 2nd 2024
- Has thanked: 1258 times
- Been thanked: 1471 times
Hi all,
The Western limb is just loaded with prominences, a really big hedge prom and lots of surge proms and some looping going on near all those active regions hugging the limb. Lots of activity should be really great for anyone doing an animation of this area. The loops are incredibly faint but they're there. I had to do a mosaic to capture all of the limb area, which I typically do not like to do in variable seeing conditions, but it seemed to have worked out ok. I included an inverted image only to really show the faint proms as its easier to pick out I think. Otherwise, the typical native B&W and false colored (to match what is seen visually when I view).
Equipment:
Aries Tri-Band D-ERF (1) -> 150mm F8 Doublet -> Baader Red CCD-IR Block Filter (D-ERF 2) -> Air Spaced Etalon 1 -> Baader TZ4 Telecentric -> Air Spaced Etalon 2 -> Blocking Filter -> IMX432 Sensor
Equipment:
- Has thanked: 276 times
- Been thanked: 131 times
Re: Monster Prom & Activity on the Western Limb | HA High Res | May 2nd 2024
Wow! That is incredible Marty.
Stage 2 mod completed @ 100, 127.
Istar 228 arrived, building the frame slowly while learning cnc.
This is a mesmerizing proms, very well done.
Alexander.
Alexander.
- Has thanked: 2572 times
- Been thanked: 5090 times
Excellent images Marty.
- Has thanked: 3356 times
- Been thanked: 1912 times
Nice to see the details.
I had a poor observing session through haze and a power plug issue again.
Cheers. Andrew.
Cheers. Andrew.
- Peterm
- Has thanked: 1949 times
- Been thanked: 1707 times
Stunning Marty. Great you presented several versions. Without doubt that inverted image is the absolute knock out for me. I can never get my head around why some are "negative" to them. As your images show there is much more faint and fine detail available as per the loops.
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- rigel123
- Has thanked: 9023 times
- Been thanked: 9243 times
Gorgeous shots Marty! I'll have to go back over my animation to see if there is a way to bring out the loops.
- Has thanked: 6573 times
- Been thanked: 7683 times
Wonderful results Marty!
- Has thanked: 21534 times
- Been thanked: 10953 times
A pleasure to see thanks MArty!
- Has thanked: 1994 times
- Been thanked: 1435 times
excellent images
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
