Coronado SM90 type 2 ITF
rcwinter
Has thanked: 191 times
Been thanked: 272 times
Post by rcwinter »
I have been waiting an age for a replacement ITF for the above scope
Its the Beloptic version from Oliver S.
Still no sign of the filter and Oliver has no idea when they will arrive.
I noted on the chat group the some have been using substitute filters l like the Baader 35nm H Alpha as an example
I would really like to use my scope but the ITF is so poor i struggle to use it effectively
Does anyone have a spare BF30 knocking about, bought as a spare or know where i can get one easily
Vixen SP102M, C,oronado SM90 Type 2 BF30< Takahashi FSQ106N, Daystar Quantum SE .4ang, ZWO ASI 174MM Cool, ASI 2600mm, Antila 2” .3ang Ha/So/O3, ASI 220MM, 290MM, 224MC, Lumenera Skynx & Infinity 2, ASI AIR Pro Plus
rsfoto
Has thanked: 10719 times
Been thanked: 6219 times
Re: Coronado SM90 type 2 ITF
Post by rsfoto »
Do you have a BF30 ? Just replace the ITF with an H-alpha filter Like I did, see below
viewtopic.php?t=44840
Has thanked: 22413 times
Been thanked: 11473 times
Let us know when Oliver gets stock back in...
rcwinter
Post by rcwinter »
I will do, currently experimenting with H-alpha- 45nm and 7nm plus UV/IR filter
Even the RG3 IR /UV seem to be out if stock
rcwinter
Post by rcwinter »
Hi Mark, tried out the fix with the 45nm, worked ok, would the 7nm be better or just stick with the 45nm, of another ?
rcwinter
Post by rcwinter »
Quick note to all who have been waiting
Oliver emailed this morning to say the ITF BF30 are back in stock.
Thanks to all who commented and advised, the H-alpha filter as a replacement works well for imaging
Grab your BF30 while they are available
VasilevIvan
Has thanked: 482 times
Been thanked: 345 times
Post by VasilevIvan »
Good news - Oliver has received new ITF-filters. I place order 2 weeks ago and i have received ITF-filter for BF15 yesterday. But i don't know about BF30.
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
