6 hours 55 min FD timelapse of the Sun in H-Alpha on 13th of May 2024.
arnedanielsen
Has thanked: 7764 times
Been thanked: 9226 times
Post by arnedanielsen »
Dear friends,
Here's a time-lapse animation created from 697 recordings between 08:13 and 15:08UT on May 13th 2024. Each recording was 20 seconds long with a framerate of 40fps (600 frames) and 10 seconds delay between each recording.
The recordings where obtained using a Coronado SolarMax 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ZWO ASI 178mm. Everything was mounted on a SkyWatcher SolarQuest mount.
The best 100 frames from each recording was stacked in AutoStakkert!4 before they were aligned and sharpened in ImPPG.
The final animation was created in PIPP at 12fps effectively compressing the 6 hours 55 minutes of duration down to just 58 seconds.
Click on the image to view the timelapse on AstroBin.
Thanks for looking
Arne
Albireo
Has thanked: 101 times
Been thanked: 176 times
Re: 6 hours 55 min FD timelapse of the Sun in H-Alpha on 13th of May 2024.
Post by Albireo »
Awesome Arne! Thanks for sharing 🙂
Did you try to derotate it?
Also I can only imagine how much disk space that must have needed. I can barely fit more than 2h on my disk before I need to take a break and put everything on my external drive to go on (and that is with a 1-minute cadence compared to your 30s cadence). Any tips on that? 😂
Lunt 40 LS40T Ha B600
Orion Shorttube 80
Sol'Ex
SkyWatcher Solarquest
Skywatcher HEQ-5
ZWO ASI174MM
2x Barlow
5x Barlow
rigel123
Has thanked: 10609 times
Been thanked: 10596 times
Post by rigel123 »
That is excellent Arne!
nicspenceryork
Has thanked: 7210 times
Been thanked: 1779 times
Post by nicspenceryork »
Awesome animation Arne. Is so interesting to watch the full disc animation because it allows you to choose where to watch simultaneous activity which may/may not be linked across the whole sun rather than be restricted to the small areas which are commonly recorded. Hard to word the sentence!
Nic
Ivan
Has thanked: 3820 times
Been thanked: 2667 times
Post by Ivan »
I can't stop admiring your work Arne!
Ivan
Has thanked: 23748 times
Been thanked: 12123 times
Very nice thanks Arne!
MAURITS
Has thanked: 2858 times
Been thanked: 5433 times
Post by MAURITS »
Excellent Arne.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Gordon Ewen
Been thanked: 258 times
Post by Gordon Ewen »
Very cool, Arne. I ought to have a go at full disc animation but I find the Lunt 152, when used with big chip, has an uneven tuning on one side of the image. Also, with the double stack there's no room for reducer. I'd have to try single stac with a reducer.........
Lunt 152 DSII Ha scope, Orion Optics 12" ODK, C9.25
Skywatcher EQ8 x 2
Lunt 1 1/4" Herschel Wedge, 2x,3x Barlow, 5x Powermate, Baader Ca filter and solar film.
https://www.flickr.com/photos/74614447@N02/
Andy Devey
Been thanked: 82 times
Post by Andy Devey »
Stunning capture and presentation Arnie.
Regards
Andy
Has thanked: 10670 times
Been thanked: 7125 times
Post by ffellah »
Amazing full disk animations, Arne ! Perfection in imaging…
Franco :bow
Peterm
Has thanked: 2242 times
Been thanked: 1991 times
Post by Peterm »
Oh gee whizz Arne, this is stunning to what on the 32inch monitor zoomed in. All, do yourself a favour and watch on a big monitor! Bravo!
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
y3000
Has thanked: 18 times
Been thanked: 103 times
Post by y3000 »
amazing!
arnedanielsen
Thank you very much for your kind comments everyone! Much appreciated!!
Arne
arnedanielsen
Albireo wrote: Tue May 14, 2024 7:27 pm Awesome Arne! Thanks for sharing 🙂
Thanks! :-)
I haven't tried to derotate it!
I'm recording directly to fast external SSD's. This makes it possible to swap drives if I run out of diskspace as well as being very practical for moving the recorded data to my desktop computer for processing!
I'm using these 4TB external SSD's from Samsung:
https://www.samsung.com/us/computing/me ... pe4t0s-am/
Arne
arnedanielsen
Gordon Ewen wrote: Fri May 17, 2024 6:49 am Very cool, Arne. I ought to have a go at full disc animation but I find the Lunt 152, when used with big chip, has an uneven tuning on one side of the image. Also, with the double stack there's no room for reducer. I'd have to try single stac with a reducer.........
I think smaller scope and shorter fl is more suited for FD's. Makes everything more simple. The Lunt 152 excels when used for high-res work.
Arne
Albireo
Post by Albireo »
arnedanielsen wrote: Sat May 18, 2024 11:26 am
It's quite easy to do this with Davinci Resolve, it does a great job, even with my not always clean frames. Yours should be straight forward. Let me know if you need any help 😉
Ah, good to know. I'm just concerned about sharing the USB traffic. I'm sometimes dealing with (many) corrupted frames (even when only my camera is plugged in) and I fear this would make it worse... But it's definitely something worth trying. I'd love to get a smooth animation spanning many hours 😄
Orion Shorttube 80
Sol'Ex
Skywatcher HEQ-5
ZWO ASI174MM
2x Barlow
5x Barlow
