May 17 FD with 3nm CaK
SolarMathmo
Has thanked: 121 times
Been thanked: 210 times
Post by SolarMathmo »
Saw a lovely new block of spots emerging on the SDO feed so set up this morning despite the less than wonderful sky.
I'm continuing to work on my capture process with the 3nm CaK Altair filter and their Wave 125 and Hypercam 533M. I set the scope to 60mm today so my FR is now around f/16. This is certainly one of the more more contrasty and detailed FDs with this wide FWHM filter that I've had, but who knows what other factors may be at play. Seeing was all over the place in today's high haze.
Captured with Sharpcap 4.1 at 40fps, best 150 frames from 2500 stacked in AS4. My Herschel wedge was down at 0.6ND blocking which gave me 2ms exposures at a fairly modest gain. I had the tri-band D-ERF on the front to manage the energy flow to the camera down given the low blocking I'm now using. I favoured the exposure of the texture away from the spots in the processing, so the spots have ended up a bit darker than I'd like. I need to improve my curves/
Altair Wave 125mm
Altair & Baader Herschel wedges
Altair Hypercams 533M & 26M (FD) 174M (details)
Ioptron GEM45
Altair Triband D-ERF
Powermate 4X & APM 1.6
Quark
N.I.N.A. and Sharpcap for control on i5 minis.
rsfoto
Has thanked: 10588 times
Been thanked: 6175 times
Re: May 17 FD with 3nm CaK
Post by rsfoto »
Beautiful image
Has thanked: 18689 times
Been thanked: 17823 times
Post by DeepSolar64 »
Very nice!! You got very nice facular/plage detail all the way across the disc.
Bravo!!
Has thanked: 22126 times
Been thanked: 11279 times
Lovely disk! The f16 is certainly the reason for the higher constrast.
SolarMathmo
marktownley wrote: Sat May 18, 2024 6:46 am Lovely disk! The f16 is certainly the reason for the higher constrast.
Thanks - glad I took your advice!
Altair Wave 125mm
Ioptron GEM45
Quark
Has thanked: 9923 times
Been thanked: 6612 times
Post by ffellah »
Great catch of the new sunspots. Well done.
