may 18th 2024 prom with wide slit spectro
ChrisHalpha2017
Has thanked: 348 times
Been thanked: 285 times
Post by ChrisHalpha2017 »
Hello....
through a bit of clear but hazy sky before going to work this morning....
with a 1800 lines and 1200 lines it was quite good but the contrast is still a bit low...
Also i've just realized but too late that the slit wasnt set properly in the focal plane of the collimator : that's why the h alpha line edges arent well defined and sharp...and so there is a loss of resolution... I'm going to fix that detail later ^^
Again NO Stacking !! so what you see here is what you can actually see when you look through the eyepiece.. There is no enhancement appart a bit of contrast with GIMP software.
zone observée.jpg (264.66 KiB) Viewed 516 times
1200 tmm 2_20240518_062023.920_UT.jpg (79.5 KiB) Viewed 516 times
Chris
