4 hours 22 minutes timelapse of AR13679 in H-Alpha 17th of May 2024
arnedanielsen
Has thanked: 6934 times
Been thanked: 7967 times
Post by arnedanielsen »
Dear friends,
Here's a time-lapse animation created from 763 recordings between 08:00 and 12:22UT on May 17th 2024. Each recording was 18 seconds long with a framerate of 126fps (2268 frames) and 2 seconds delay between each recording.
The recordings where obtained using a using a iStar Asteria TCR 204-12 R35, with an Altair Astro 115mm TRIBAND H-Alpha D-ERF, Baader 35nm H-Alpha, Baader SunDancer II 3x Telecentric System TZ-3S, DayStar Quantum 0,4å PE and Player One Apollo-M Max mounted on a Sky-Watcher AZ-EQ6 PRO and guided with Hinode SolarGuider.
The best 200 frames from each recording was stacked in AutoStakkert!4 before they were aligned and sharpened in ImPPG.
The final animation was created in PIPP at 12fps effectively compressing the 4 hours 22 minutes of duration down to just 1 minute 3 seconds.
Click on the image to view the timelapse on AstroBin.
Thanks for looking
Arne
rigel123
Has thanked: 9360 times
Been thanked: 9577 times
Re: 4 hours 22 minutes timelapse of AR13679 in H-Alpha 17th of May 2024
Post by rigel123 »
Nice animation, Arne!
arnedanielsen
Thanks Warren!
Arne
Has thanked: 21970 times
Been thanked: 11191 times
Looks good Arne!
arnedanielsen
Thanks Mark!
Arne
