triple stack mosaic from May 20th
- Ivan
- Has thanked: 3824 times
- Been thanked: 2668 times
Hello everyone A new mosaic from May 20th. Good day, many events.
FD_20.05.24 by Ivan Sirotin, on Flickr
Ivan
Ivan
- Has thanked: 5371 times
- Been thanked: 5103 times
Re: triple stack mosaic from May 20th
Superb mosaic,Ivan.
Petr
Petr
- Ivan
Thanks a lot, Petr, I appreciate your opinion. I often watch your close-ups, and I also want to start making them, but I don't dare.
Ivan
- Has thanked: 9503 times
- Been thanked: 9232 times
Very nice indeed.
- Has thanked: 23836 times
- Been thanked: 12167 times
That's a beauty Ivan!
- Has thanked: 19420 times
- Been thanked: 18530 times
Looks good, Ivan!
- Has thanked: 20677 times
- Been thanked: 9948 times
You have been getting some absolutely superb full discs this year Ivan
Can you remind me what size the triple stack is?
- Been thanked: 3152 times
This is really splendid !
Resolution, processing, continuity between disk and prom. Everything is top !
Well done !
Well done !
- Has thanked: 1191 times
- Been thanked: 1153 times
- KMH
- Has thanked: 806 times
- Been thanked: 1142 times
- Has thanked: 2873 times
- Been thanked: 5454 times
- Martin_S
- Has thanked: 1301 times
- Been thanked: 3568 times
This is amazing work Ivan, what camera and exposure settings are you using for triple stack imaging?
Martin
Martin
Skywatcher 120mm F8.3 open frame refractor, 2" Antlia dual band ERF filter as a sub energy rejection filter, Flip Mirror to either a Baader TZ4 telecentric focal extender, Combo Quark Chromosphere, Naked PST etalon for double stacking, ASI74mm camera, or an Antlia 5a Cak filter, ASI290mm camera. 100mm aperture is stopped down to 50mm for Cak.
- Ivan
Thanks a lot, Stuart! Your FDs are great!
Ivan
Thanks a lot, Mark!
Ivan
Thank you very much, my friend!
Ivan
Thank you very much, Alexandra!
I try to improve my skills and setup. I use an external etalon 50mm and two internal etalons Lunt50 https://flic.kr/p/2pP1xGb
Ivan
Ivan
Thank you very much, Valery, your close-ups are wonderful, Quark shows very well.
Ivan
Thank you very much, Christian! I really appreciate it!christian viladrich wrote: ↑Tue May 21, 2024 12:43 pm This is really splendid !
Well done !
Ivan
Thank you very much! I usually make 12 to 15 fragments to be 100% sure that all areas are covered. But, theoretically, I can do without 9.
Ivan
Thanks a lot to Maurits!
Ivan
Thanks a lot Martin! Every time I change the settings, it depends on seeing, the presence of flares, the height of the Sun, clouds. I don't get attached to the histogram, but try to evaluate the picture to my taste. Specifically, these fragments were shot by Shutter=10.25ms
Gain=100 (18%). But I can increase the exposure (although I do it very rarely) to 20 ms. At the same time, the picture will not lose sharpness, because the scale is not very large.
Ivan
Emoticons from my daughter Regina:
- Has thanked: 7798 times
- Been thanked: 9276 times
