I had an extensive solar session on 19th May 2024. Collected 732GB of data!!!
Managed to get best solar timelapses I have ever done - quite proud! Would welcome advice on how to make them better though.
What methods do people use for stacking? Mine was done with Photoshop automatically aligning whilst creating animation.
Quark hydrogen
100mm OTA
Daystar ERF
Flatcap
174M camera
20s videos taken in Firecapture and processed in AS3 and Photoshop.
Andy
see www.astronomy.me.uk for more info.
https://youtu.be/X1Ef2fiGJtg?si=Yz1MlMsZPdDpEJjQ
https://youtu.be/ys8pJ09m3sk?si=vLl-nCeRsfIgUu3K
https://youtu.be/CJI083hCQI0?si=I3IWJTEsaMz7No8d
Prominence timelapse videos from 19/5/2024
- Has thanked: 18833 times
- Been thanked: 9221 times
Re: Prominence timelapse videos from 19/5/2024
Terrific work, the middle one shows some interesting flow, well done
I need to learn how to do Photoshop align because sometimes ImPPG just refuses to do it.
- rigel123
- Has thanked: 9365 times
- Been thanked: 9585 times
Nice animations Andy! Photoshop does a great job of aligning as long as there are clear surface features. You can see that in your first animation. When the disk is more blown out, as in your next two animations it struggles, and in these cases you might try ImPPG for alignment as it handles the blown out disk better than PS.
Alexandra, aligning in Photoshop is simply selecting File/Scripts/Load Files into Stack, select all your files from Browse in the pop up box and then check the Attempt to Automatically Align button. As I mentioned, if you have surface features in your images it typically does a fantastic job of alignment. If it is proms with a blown out disk it typically fails.
- Has thanked: 21978 times
- Been thanked: 11200 times
Nice videos thanks Andy!
