Double Stack Evaluation Requested
pdmphoton
Has thanked: 263 times
Been thanked: 537 times
Post by pdmphoton »
Hello All,
I double stacked the 130MT Lunt with a front mounted Coronado 90mm DS etalon.
(Still getting use to tuning it as it is so different from a pressure tuned etalon.)
Seeing conditions were awful today with significant turbulence. Nonetheless I wanted to get some feedback from the group on a quick initial test.
First two images were captured with a ZWO 183mm and a 1.6X Barlow. Closeup of sunspot was captured with a 174mm and 2.5X Powermate.
Any helpful observations would be appreciated.
I will do a comparison test with the internal double stack vs. the front mounted Coronado in the next day or two when there are decent seeing conditions.
I will say, from just a quick visual comparison the front mounted setup appeared to have the edge.
130MT + 90mmDSII 1.6X Barlow 183mm copy.jpg (12.26 MiB) Viewed 730 times
130MT + 90mmDSII 1.6X Barlow 183mm INV BW copy.jpg (11.46 MiB) Viewed 730 times
130MT + 90mmDSII 174mm 2.5X PMT copy.jpg (983.1 KiB) Viewed 730 times
Thank you,
Paulm
Lunt LS80Tha DS
Lunt 130MT DS
APM 140 Doublet
Skywatcher 180mm Mak
Celestron C11 XLT
ZWO 174 and 183 Mono
iOptron CEM120
Hinode Solar Guider - Airylab SSM
Has thanked: 18657 times
Been thanked: 17799 times
Re: Double Stack Evaluation Requested
Post by DeepSolar64 »
Paul,
I think these look good. You appear to be on band. Your top disc looks to be evenly tuned and illuminated. Something that troubles me to no end in doublestack. I think your test is successful.
pdmphoton
Post by pdmphoton »
DeepSolar64 wrote: Wed May 22, 2024 1:38 am Paul,
James,
Thank you for your helpful response. I find that double stacking with the Lunt internal etalons, while convenient, presents challenges with reflections.
While there are methods to deal with the reflections the "solutions" reduce light throughput too much for my taste. I am hoping I will be able to dial in the Coronado DS unit to obtain full discs with the Lunt 130MT.
Lunt LS80Tha DS
Lunt 130MT DS
APM 140 Doublet
Celestron C11 XLT
iOptron CEM120
pdmphoton wrote: Wed May 22, 2024 2:47 am
James,
Good luck Paul. I think you are on your way to achieving your goal with the 130MT and Coronado etalon.
pupak
Has thanked: 4821 times
Been thanked: 4427 times
Post by pupak »
The most challenging thing about the DSII is to tune them so that there is a contrasting surface and at the same time the prominences are clearly visible. I got the best results with the LS40 and Quark combo. Full discs are a demanding discipline if you want high resolution. Your photos are very good.
Has thanked: 22072 times
Been thanked: 11242 times
Looks good Paul
Has thanked: 8897 times
Been thanked: 8679 times
Post by Carbon60 »
Looking great, Paul. You'll refine with practice.
MAURITS
Has thanked: 2651 times
Been thanked: 5186 times
Post by MAURITS »
Well done Paul.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
