Wednesday Full Disc and More
pdmphoton
Has thanked: 248 times
Been thanked: 524 times
Post by pdmphoton »
Continuing to refine tuning with the Lunt 130MT internal pressure tuner combined with a Coronado 90mm DSII.
Full disc images with the 183mm.
Close ups with a 174mm and 2.5X Powermate.
Very good seeing this morning in Meadview, AZ
Best,
Paul
130MT + 90mmDSII BW POS 3 copy 2A.jpg (6.6 MiB) Viewed 548 times
130MT + 90mmDSII Color POS 3 copy.jpg (11.59 MiB) Viewed 548 times
2.5X Powermate Color copy.jpg (1.23 MiB) Viewed 548 times
2.5X V2 Color copy.jpg (1.3 MiB) Viewed 548 times
2.5X Powermate V4 Color copy.jpg (1.76 MiB) Viewed 548 times
Lunt LS80Tha DS
Lunt 130MT DS
APM 140 Doublet
Skywatcher 180mm Mak
Celestron C11 XLT
ZWO 174 and 183 Mono
iOptron CEM120
Hinode Solar Guider - Airylab SSM
AstroBees
Has thanked: 245 times
Been thanked: 294 times
Re: Wednesday Full Disc and More
Post by AstroBees »
Fantastic images!
So are you giving up resolution using the 90mm second stack in order to gain the benefits of the double stack?
Lunt 80mm Ha double stack
Explore Scientific ED152 CF APO with Baader ASTF Whitelight film & Baader Solar Continuum filter
All piggybacked on a Astro-Physics Mach 1.
pdmphoton
Post by pdmphoton »
AstroBees wrote: Wed May 22, 2024 10:21 pm Fantastic images!
Thank you for the compliment!
I do have the internal double stack unit for the 130MT. My seeing conditions are such that I frequently mask the scope down to 100mm. Double stacking the Lunt scopes with their internal etalons results in reflections that can be mitigated with a polarizing filter, however you lose a lot of light. Based on a suggestion from a well respected solar imager I am giving the front mounted 90mm DS a try as it eliminates the problem of internal reflections. I am actually finding that it does a better job than the Lunt DS unit when I am imaging a full disc with this scope.
I will switch to the Lunt DS unit in when I am after close-ups. Right now I am after a 1600mm that I will combine with a 1.25X Barlow which I believe will be an excellent combination for full discs without doing a mosaic.
Lunt LS80Tha DS
Lunt 130MT DS
APM 140 Doublet
Celestron C11 XLT
iOptron CEM120
AstroBees
Post by AstroBees »
PM sent to you.
Has thanked: 18584 times
Been thanked: 17732 times
Post by DeepSolar64 »
Nice work Paul!!
MAURITS
Has thanked: 2633 times
Been thanked: 5176 times
Post by MAURITS »
Well done Paul.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
cybermayberry
Has thanked: 1998 times
Been thanked: 1442 times
Post by cybermayberry »
excellent
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
Has thanked: 21946 times
Been thanked: 11182 times
Great images Paul!
arnedanielsen
Has thanked: 6934 times
Been thanked: 7967 times
Post by arnedanielsen »
Excellent results, Paul!
Arne
