Closeup of selected AR in H-Alpha using the 204mm refractor 18th of May 2024
arnedanielsen
Has thanked: 6998 times
Been thanked: 8066 times
Post by arnedanielsen »
Dear friends,
Some closeups of active regions in H-Alpha from May 18th 2024.
Click on images to view them in full size on AstroBin.
The recordings where obtained using a using a iStar Asteria TCR 204-12 R35, with an Altair Astro 115mm TRIBAND H-Alpha D-ERF, Baader 35nm H-Alpha, Baader SunDancer II 3x Telecentric System TZ-3S, DayStar Quantum 0,4å PE and Player One Apollo-M Max mounted on a Sky-Watcher AZ-EQ6 PRO and guided with Hinode SolarGuider.
AR13683
AR13674
AR13679
AR13685
Arne
Has thanked: 9923 times
Been thanked: 6612 times
Re: Closeup of selected AR in H-Alpha using the 204mm refractor 18th of May 2024
Post by ffellah »
Superb closeups and processing, Arne. First two have my favorite processing.
Franco :bow
eroel
Been thanked: 5125 times
Post by eroel »
Arne:
Superb clean crisp images.
Thanks and best regards.
pupak
Has thanked: 4845 times
Been thanked: 4457 times
Post by pupak »
Excelent details, Arne.
Petr
KMH
Has thanked: 717 times
Been thanked: 921 times
Post by KMH »
Terrific images and processing!
Kevin
Has thanked: 22126 times
Been thanked: 11279 times
Great shots with the big scope thanks Arne!
arnedanielsen
Thank you very much Franco, Eric, Petr, Kevin and Mark!
Franco: I think the difference is mostly down to varying seeing. All images are a stack of 200 images and ran through iMPPG with the same amount of sharpening. Contrast stretching was done individually in PhotoShop.
Arne
Martin_S
Has thanked: 1097 times
Been thanked: 3267 times
Post by Martin_S »
Great hi res imaging Arne, thanks for sharing .
Martin
rsfoto
Has thanked: 10574 times
Been thanked: 6175 times
Post by rsfoto »
Excellent images with very fine sharp details
arnedanielsen
Thank you very much for your kind comments Martin and Rainer!
Arne
Has thanked: 18689 times
Been thanked: 17823 times
Post by DeepSolar64 »
Very nice work Arne. 204mm...WoW!!
vineyard
Has thanked: 957 times
Been thanked: 918 times
Post by vineyard »
Outstanding. You should use that setup more when seeing allows.
nicspenceryork
Has thanked: 6652 times
Been thanked: 1564 times
Post by nicspenceryork »
So interesting to see the beautiful results with your large aperture scope.
Nic
rigel123
Has thanked: 9459 times
Been thanked: 9647 times
Post by rigel123 »
Excellent session Arne!
arnedanielsen
Thank you very much for you kind comments everyone! Much appreciated!
Arne
