Less is more
nicspenceryork
Has thanked: 6652 times
Been thanked: 1564 times
Less is more
Post by nicspenceryork »
Hi all,
Here's a couple of images of the same active region a few days apart.
I've been stopping down G Band from 80 to 60 because I'd got used to stopping down to 60 for CaK. It seemed to give good results and then on a day I tried it with full 80 aperture the results were no better so I stuck with 60. How many times have we all done that?! Tried it once and made the wrong assumption when it was likely seeing or some other factor at play! After completing the Excel document Stu recommended in the last zoom meeting, I felt I should try again... glad I did! I caught more detail at full aperture so I could strip back the processing even further. The first is stopped to 60 and then more intensely processed. The second is full 80. I also revisited number of frames in the stack. In the first is 100 and in the second is 120. I think the results speak for themselves!
ImageNS 19052024 0953 Sun G Band AR3685 3686 by Nic Spencer, on Flickr
ImageNS 25052024 0704 Sun G Band AR3679 3684 3685 3686 by Nic Spencer, on Flickr
Last edited by nicspenceryork on Sat May 25, 2024 7:26 pm, edited 2 times in total.
rigel123
Has thanked: 9431 times
Been thanked: 9629 times
Re: Less is more
Post by rigel123 »
Great shots Nic!
Alto
Has thanked: 1090 times
Been thanked: 445 times
Re: Less is more
Post by Alto »
Great detail there.
Call me Geoff.
arnedanielsen
Has thanked: 6990 times
Been thanked: 8058 times
Re: Less is more
Post by arnedanielsen »
Great results, Nic!
Arne
eroel
Been thanked: 5123 times
Re: Less is more
Post by eroel »
Nic:
Beautiful images.
Thanks for sharing them.
Best regards.
KMH
Has thanked: 716 times
Been thanked: 919 times
Re: Less is more
Post by KMH »
Terrific, and an interesting comparison.
Kevin
Has thanked: 18669 times
Been thanked: 17811 times
Re: Less is more
Post by DeepSolar64 »
Looks great, Nic!
Has thanked: 22096 times
Been thanked: 11251 times
Re: Less is more
Nice results Nic! Have you a link to the excel file you can share?
nicspenceryork
Re: Less is more
Thanks all, you're very kind.
marktownley wrote: Sun May 26, 2024 6:25 am Nice results Nic! Have you a link to the excel file you can share?
Yes here it is from MalVeauX within the conversation
viewtopic.php?t=32595
Has thanked: 9898 times
Been thanked: 6598 times
Re: Less is more
Post by ffellah »
These are excellent, Nic, well done !
vineyard
Has thanked: 947 times
Been thanked: 911 times
Re: Less is more
Post by vineyard »
Beautiful. And yes that spreadsheet by Marty is very useful - I've used it write down a bunch of different combinations!
nicspenceryork
Re: Less is more
vineyard wrote: Sun May 26, 2024 10:14 am Beautiful. And yes that spreadsheet by Marty is very useful - I've used it write down a bunch of different combinations!
Thank you . Yes, you're right. Taking the time to complete it with various combinations helped me to further understand how manipulating the variables in situations can help to get the best from available equipment.
Nic
