May 26 2024. Lunt 8x32 WL SUNoculars.
Has thanked: 18669 times
Been thanked: 17811 times
Post by DeepSolar64 »
Today has been a busy and mostly cloudy day. After church and errands I finally got the sun between clouds in a mostly cloudy and hazy sky using my little Lunt 8x32 solar binoculars. The time was around 20:15 UTC and the temperature was a hot 88F ( 31.1C )
I could see five active regions on the white light Sun. Two in the northern hemisphere and three is the southern hemisphere. All labeled.
AR13691 could be seen as a large easy spot near the NE limb. Just to it's SW I could also see the much smaller spot of AR13690. I see nothing in the NW quadrant.
In the SW quadrant I can see AR13685 as two spots. A large one with a small one just to its SW. Close by to the NE, AR13686 could be seen as a small spot. The SE quadrant shows a single active region, this is AR13692 which could be seen as a single spot.
Carpe Lumen!!
Has thanked: 22096 times
Been thanked: 11251 times
Re: May 26 2024. Lunt 8x32 WL SUNoculars.
Glad you got a view in James!
Petrus
Has thanked: 1724 times
Been thanked: 871 times
Post by Petrus »
Great report James!
~ Petrus ~
Flickr
Has thanked: 9898 times
Been thanked: 6598 times
Post by ffellah »
Thank you, James
Thanks and welcomes. I barely got a view in. I have predicted strong thunderstorms today.
arnedanielsen
Has thanked: 6990 times
Been thanked: 8058 times
Post by arnedanielsen »
Thanks for the report, James!
Arne
MAURITS
Has thanked: 2651 times
Been thanked: 5186 times
Post by MAURITS »
Thanks for the report James.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
You are welcome, Arne and Maurits. 😊
