X2.9 Flare!
Has thanked: 18669 times
Been thanked: 17811 times
X2.9 Flare!
Post by DeepSolar64 »
This morning I awoke to an X2.9 flare alert on SpaceWeatherLive and also read a post by PeterM on the event concerning the flare and it's possible association on the returning AR13664 which of course will be relabeled. AR13664 is the active region that gave off most of the M and X class activity on the last pass around. It looks like it may not be dead yet! Here is some data I obtained online concerning the flare. One image from SWL and the others through Helioviewer. All use SDO data.
Has anyone checked out GONG yet or better yet imaged it?
https://helioviewer.org/?movieId=XcnW5
Has thanked: 18937 times
Been thanked: 9272 times
Re: X2.9 Flare!
WOW!!!!
rigel123
Has thanked: 9431 times
Been thanked: 9629 times
Re: X2.9 Flare!
Post by rigel123 »
That’s the region I’m recording the post flare loops now. Clouds interrupted the Ha so switched over to CaK in hopes of catching them and now grabbing frames for a (cross your fingers) animation of them in CaK too. Seeing isn’t great though!!
Re: X2.9 Flare!
Good luck Warren. I am under strong thunderstorms so there is no sun for me.
pedro
Has thanked: 15 times
Been thanked: 7106 times
Re: X2.9 Flare!
Post by pedro »
I was able to capture the post-flare loops this morning - quite spectacular
AndiesHandyHandies
Has thanked: 3389 times
Been thanked: 1917 times
Re: X2.9 Flare!
Post by AndiesHandyHandies »
I luckily saw it at 1.20 BST.
Santel Rumak 180, 2" Energy dump, ES 2" 2x, 1.25" Energy dump, UV/IR, Red CCD, Baader 7nm, T2 Prism, Quark Prom, DS PST Etalon, 40mm Celestron Symetric. First decent view, 2nd.
I can see some details on the surface so could have a nice view of the filaprom. The coronal loops had bright mushroom tops for me. There was a faint upward 45Deg spike going to the filaprom above.
Cheers. Andrew.
steveward53
Has thanked: 1394 times
Been thanked: 1683 times
Re: X2.9 Flare!
Post by steveward53 »
And you know it was a violent release when it shows like this on the AIA 1600 A data ... :o
The CME as a .gif.
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
Has thanked: 22096 times
Been thanked: 11251 times
Re: X2.9 Flare!
Way cool! I got it in CaK, just processing...
Re: X2.9 Flare!
Andrew,
It is so nice to see a visual report of this event. Nicely done!
Steve,
Thanks for the additional data. The flare ejecta shows up really well at the AIA1600 wavelength. This was at or very close to the time of the flare just before the loops formed. If only one of our CaK imagers would have been up and running at that time. The CME from the event looks significant as well but being on the limb will not be Earth directed.
Mark,
Your CaK work on the event was awesome!!
All,
Below is a GONG colorised Ha image of the event.
P.S. And Pedro, Awesome work on those images!!
20240527070442_GONG_LSO_Australia_ Ha_X2.9_JP.jpg (1.63 MiB) Viewed 423 times
steveward53
Re: X2.9 Flare!
It should also be noted that the X-2.9 valuation is likely a lot lower than the flare actually produced , as the source was still behind the limb and the x-ray detectors only caught a relatively small part of the blast.
Steve.
MAURITS
Has thanked: 2651 times
Been thanked: 5186 times
Re: X2.9 Flare!
Post by MAURITS »
Thanks for the report James, I'am glad to see this here because again rain in Belgium.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Re: X2.9 Flare!
steveward53 wrote: Tue May 28, 2024 4:46 am It should also be noted that the X-2.9 valuation is likely a lot lower than the flare actually produced , as the source was still behind the limb and the x-ray detectors only caught a relatively small part of the blast.
Would it be lower or higher? After all some of the flare may have been obscured by the limb. I have also wondered if a just behind the limb flare would affect the x ray output the GOES satellites would see.
Re: X2.9 Flare!
Maurits,
You are welcome. I had rain yesterday but clearing skies today. Good luck on your weather.
