27 May 2024 - Gband - w aperture stepdown
- Has thanked: 1197 times
- Been thanked: 1158 times
Based on advice from Mark, and seeing there was a short stint of sunshine this morning, I quickly tried 3 different apertures - the native 102mm of the ST102 (so f5), and then 80mm (equiv f6.3), and then 60mm (equiv f8.3). Exact same number of exposures, same % stacked, same ImPPG curve, same GIMP curves. There will be some seeing difference but it wasn't that variable over the 3-4 minutes. The aperture step down makes such a difference - thanks Mark!
I think the 60mm is sharpest at Gband, but the 80mm doesn't seem that far away from it?
102mm
80mm
60mm
ROI at bin1
Same ROI at bin2 w a 2.5x powermate - I actually should have stuck to bin1 as per Marty's spreadsheet
I tried the aperture step down for 540nm continuum as well. Not as much of a difference as in Gband, although the 80mm is still better than the 102mm?
102mm
80mm
60mm
102mm
80mm
60mm
ROI at bin1
102mm
80mm
60mm
- Has thanked: 23839 times
- Been thanked: 12169 times
Re: 27 May 2024 - Gband - w aperture stepdown
Great comparison Vin! Less is more
- Has thanked: 19448 times
- Been thanked: 18542 times
Vinyard,
I have certainly benefited by stopping my AT72EDII down from 72mm to 40mm while imaging at 430nm and 393.3nm. Mark's advice has proven spot on.
- Has thanked: 348 times
- Been thanked: 286 times
very nice series ^^
- Has thanked: 10716 times
- Been thanked: 7166 times
- rigel123
- Has thanked: 10718 times
- Been thanked: 10687 times
- Has thanked: 2873 times
- Been thanked: 5454 times
- Been thanked: 3152 times
Well done !
The 60 mm aperture is clearly the winner in G-band.
- Has thanked: 7804 times
- Been thanked: 9285 times
Thanks both Christian & Arne. Been having a learning curve today in v windy conditions in SW Portugal...ooph.
